HVAC control sliders
Old Sep 22, 2012 | 12:32 PM
Cmayer's Avatar
Does anyone have an image of the HVAC controls out of an '86-'89 4runner?
I finally decided to fix my AC and the first step is to figure out why my temperature slider doesn't work. It appears that it's missing a nut to attach that one control lever.
Here's the lever removed from the threaded screw. Do I just need a nut to put that lever back on?
Also, how the heck does the HVAC come out with the metal support right behind it?
Old Sep 22, 2012 | 06:52 PM
slow-mo's Avatar
I don't see that part in the parts fiche. You might have to improvise or scavenge it off a wrecker.
http://www.utoyot8.com/images/147907305/247983750.png
http://www.toyotapartseast.com/components/toyota-1987-truck-pickup_heating-air-conditioning-control-air-duct-87-15-11575.html
Old Sep 22, 2012 | 06:58 PM
Cmayer's Avatar
Thanks! The images really help see what should be there.
Guess the previous owner tried to rig something up and failed. I ran a new M4 bolt, washers, and nut for now. It works, but to get it tight enough to not wobble causes to much drag.
I'll look next time I go to a wrecking yard.
Old Oct 18, 2012 | 06:22 PM
kustomguitarist's Avatar
what's the best way to gain access to the HVAC controls? I'm having the same issue but I can't figure out which dash pieces to remove without taking the entire dash apart.
Also, any ideas on a method to lubricate the temperature slider and the vent/defrost/heat damper control cables?
Thanks!
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Jeremy Neal
PureTacoma_Tundra
Sep 20, 2015 11:56 AM
