screw part on intake
Old Sep 14, 2012 | 03:01 PM
BigSwole's Avatar
Dont know the correct name for it. Its left my head. Just looked at it at the parts store.
Should all the passages be able to be blown through? I took it off to clean it, check it out and all nozzles except the one on my thumb. Under it. Will allow me to blow air through. That one wont let me. Like its stopped up.
Is it supposed to be or is it clogged?
Old Sep 14, 2012 | 03:10 PM
BigSwole's Avatar
Picture wont upload, still trying.
Its the part on dtiver side of intake. Behind tb. Screws into the intake with a adjusting screw with spring on top with 4 vacuum lines on it. The one on the bottom is the one im talking .about
Old Sep 14, 2012 | 03:44 PM
scope103's Avatar
You might want to try this one again. Even with a picture, I'm not sure I could follow your question.
Knowing which engine you're talking about could help. And I'll bet you could even find a drawing of that screw in the manual. http://www.ncttora.com/fsm/1990-1995...e/throttle.pdf
Old Sep 14, 2012 | 03:52 PM
BigSwole's Avatar
Sorry about that, frustration is getting to me.
Its a 22re trying to find the part now
Old Sep 14, 2012 | 04:01 PM
angrybob's Avatar
Click here
http://www.4crawler.com/4x4/CheapTri...ne_Pix/13.html
Old Sep 14, 2012 | 04:03 PM
BigSwole's Avatar
Ok idle up valve. Not the name i was thinking of it. Thank you for the picture .reference...
Is all 4 vacuum lines need to be clear and able to blow threw them
Old Sep 14, 2012 | 05:00 PM
angrybob's Avatar
Why did you take it off? What is wrong with it? Does your a/c not increase rpm when the clutch engages? If not, did you do the test from the link above?
I have no idea what you are talking about.
Use this pic. Which line is 'clogged'?
Old Sep 14, 2012 | 05:02 PM
BigSwole's Avatar
The one on the bottom under the part
Old Sep 14, 2012 | 05:04 PM
BigSwole's Avatar
I took it off trying to track down my problems. Im on the edge of ripping this thing out and replacing the whole motor!
Doug4320
Mar 24, 2018 10:11 PM
Jonny246
Jul 12, 2015 04:51 AM
akaphilly
Jul 9, 2015 02:34 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
