How do I Measure the length for a cv rear driveshaft??
Old 09-28-2012, 04:00 PM
Dicintio619's Avatar
Hey guys im going to convert my rear driveshaft to a cv style driveshaft using a front cv shaft off of another yota but i am wondering how do i know how much it needs to be extended. Do i just measure yolk to yolk? How much compression and extension do I need to be safe???
Any help or suggestions are appreciated
Thanks, Niko
Old 09-28-2012, 05:28 PM
Valerik's Avatar
Why are you wanting to do that? Are you doing independent suspension in the rear?
I think it depends on how far your axles will travel and what not. A yoke to yoke measurement might work, depending on how you are doing the suspension. Take out your front CV axles and measure for a good general idea.
Old 09-28-2012, 07:55 PM
Im doing it because my truck is lifted to high for a regular u joint at each end drive shaft. I think you might be confused. I'm talking about a double cardan or cv joint driveshaft.
Old 09-28-2012, 07:59 PM
yotaman85's Avatar
with a tape measure.....
Old 09-28-2012, 08:01 PM
yotaman85's Avatar
if its the rear you can rotate the axle. try that before spending money on a new drive shaft..
Old 09-29-2012, 08:13 AM
Rotating the axle won't work and that isn't the correct geometry for a u joint style driveshaft and I'm pretty picky and want it right
yourrealdad
07-21-2015 11:13 AM
94yotaMI
07-21-2015 05:47 AM
CanRunner
07-20-2015 01:29 PM
TURBOrunnerNM
07-20-2015 08:31 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: How do I Measure the length for a cv rear driveshaft??
