Front diff drive flange seal
Old Sep 17, 2012 | 07:55 PM
acerbis's Avatar
I have a 87 4x4 pickup and I need to get the drive flange out to replace the seal and bearings. My manual says to use a slide hammer with a special tool that fits onto the flange. I just want to make sure there isn't a circlip or retainer that will be busted off if I use that slide hammer. Has anyone replaced the passenger drive flange seal and if so can you let me know how to get it separated from the front diff? thanks
Old Sep 18, 2012 | 11:09 AM
rattlewagon's Avatar
I pryed min out with 2 large screw drivers. Popped right out really...
https://www.yotatech.com/forums/f116...issues-238690/
Just because you weren't clear, the seal can be changed while the diff is still in the truck, but to change the bearings, you have to remove the 3rd from the truck. And dont forget to re-set up your gears after.
Hope that helps!
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
