CEL Flashing Repeatedly when Pulling Codes
Old Sep 14, 2012 | 06:49 AM
PirateYota's Avatar
First post here and I have searched for the answer for this. I hope I haven't overlooked it.
I pulled the codes when I got my truck and had a 14, 21 and 42. The truck runs great in open loop, but once warm it loses all power. I knew the truck was missing the Cat and O2 sensor so I had them installed. After installation, I tried resetting the codes by pulling the EF1 fuse. When I used the paper clip to reread the codes because it is still running poorly when warm, I am getting a repeated flashing of the CEL (no codes, but constant flashing).
First, what does the constant flashing mean?
Second, anyone have troubleshooting tips for the poor performance when warm?
Old Sep 14, 2012 | 06:56 AM
PirateYota's Avatar
Sorry I forgot to mention.
The truck is a 1992 3VZE manual 4WD
Old Sep 14, 2012 | 07:06 AM
snobdds's Avatar
A constant flashing means no codes.
Therefore, your problems are mechanical and not electrical/sensor based.
Start with the basics...
Fuel
Air
Spark
Combustion
Timing
Old Sep 14, 2012 | 07:25 AM
scope103's Avatar
Well, it could be electrical/sensor, just not the sort of failure that the ECM is set up to detect. (After all, spark is electrical.)
I would check the timing first. Easy to do, and timing-off could cause your symptoms. You'll need a very basic timing light, but they are cheap and necessary.
Old Sep 14, 2012 | 07:45 AM
snobdds's Avatar
Spark is picked up by the ECU through the signal generator in the dizzy that is then relayed back to the coil/igniter that in turns tells the ECU to fire the fuel injectors. Now I agree that it can't tell whether an individual spark plug is working, but the system is controlled by the ECU and would throw a code if it's not working. In fact the code for a 22re is 12 by the way. I just went through this with a bad signal generator in the dizzy.
Old Sep 14, 2012 | 09:22 AM
scope103's Avatar
Just as an example, if the spark plug gap is wrong, I'm pretty sure the igniter will still produce the IGF signal even though the spark plug does not actually fire. (Same with a broken plug wire.) So no codes. www.autoshop101.com
The codes are designed to tip you off to failures that are difficult to find with the usual methods (like an igniter that is failing to produce the ignition pulse). But they don't let you off the hook for ordinary diagnosis. As snobdds said, fuel, air, spark, combustion and timing are needed, they're all (partially) electrical, and none of them throws a code every time they're off.
Old Sep 14, 2012 | 09:27 AM
PirateYota's Avatar
Thanks guys! I'll start working on these tonight and I will post any updates I have.
raptor510
Feb 17, 2017 07:11 AM
256mbaker
Jul 31, 2015 06:45 PM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Roger Borba II
Jul 9, 2015 05:05 PM
