just wondering...
Old Sep 16, 2012 | 11:42 PM
Leonide's Avatar
just wondering...
i think my truck is an anomaly.... (1988 Pickup shortbed)
my truck can -easily- hit 70 - 75 mph without even trying. it accelerates uphill in 5th gear. i don't need to downshift on an uphill...depending on grade mostly. i hit 75mph in 5th at 3000 (which probably indicates a stock gear ratio).
i have no problems outrunning other people on the highway, and my truck twists on takeoffs from red lights.
the PO said he had gone through the motor after a headgasket blow, and rebuilt the engine. just wanting to know how normal my engine is for a 22RE...just gauging my engine with other 22RE owners here...
(i have stock 225 75/15 tires btw.)
reason why i am asking, is because i plan on long tubes and a cam for my motor...kinda wanting to know if the PO actually has done something to the engine.
Old Sep 16, 2012 | 11:51 PM
TNRabbit's Avatar
2wd?. That would be it. Short bed 2x4 is 1000 lbs lighter~
Old Sep 17, 2012 | 12:39 AM
Terrys87's Avatar
Looked at your profile and dont see where you have a 2 or 4 wheel drive. Sounds like a 2 wheel and they will go for a 4 cylinder.
Old Sep 17, 2012 | 12:58 AM
Leonide's Avatar
sorry, my truck is a 4x4, gear driven transfer case. IFS front end.
Old Sep 17, 2012 | 04:28 AM
waskillywabbit's Avatar
A fresh 22RE built stock will do this easily. Mine did.
Most here are bitching about a motor with 250k plus on it.
:wabbit2:
Old Sep 17, 2012 | 06:19 AM
kawasakilewis's Avatar
i have a 91 2wd auto with 86000 that will hit 90mph like its nobodys business, but then i have a 87 4wd 5speed with 164000 that wont go more than 45 up a slight grade in 3rd or 4th gear. i have no idea. i think they all just have a personality. haha. i can also bring my front tires of the ground about 3-4inches by pumping the gas like 2-3 times in my 4x4 and it has 33s
Old Sep 17, 2012 | 07:27 AM
toyota4x4907's Avatar
:wabbit2:
And most people are running larger than stock tires on stock gears, or are just under-geared.
Old Sep 17, 2012 | 07:33 AM
Yep that too!
My 85 on 4.88s with fresh 22RE would accelerate uphill in 5th with 37s easy.
:wabbit2:
Old Sep 17, 2012 | 04:09 PM
drew303's Avatar
Sounds normal. I can kinda accelerate up a decent grade in 5th in my Truggy. Which is as aerodynamic as a brick on 37s. 5.29. Carbureted. I say kinda because it depends on the weather. ;-p
Cruising speed is 68mph.
Old Sep 17, 2012 | 06:55 PM
Leonide's Avatar
:wabbit2:
that would be it then... it confirms what i heard that the PO did in fact rebuild the engine 90,000 miles ago...
it means i have a fresh 22RE engine ready for a long life.
SMOD
Jan 20, 2015 03:02 PM
patallen
Oct 9, 2012 02:33 PM
Norrick
Mar 26, 2012 04:55 AM
BajaRunner
13
Jul 24, 2011 01:34 PM
