name this part (connect to idler arm)
Old Oct 1, 2012 | 08:42 PM
Westly7's Avatar
1992 toyota pickup 2wd M/T 22re 155k mile
i notice a "clunk" on my front end so i search and i think my idler arm is worn out,i looked under and i shake idler arm and its loose but when u see this pic
there is some "play" on that shinny metal matter of fact its alot of play up and down
1.whats name of that part that connects to idler arm and goes from pass to driver?
2.is that normal to supposed to lose like that?
3.could it be the clunking noise from this part instead of idler arm?
any help will be much appreciated
thanks
Old Oct 1, 2012 | 09:11 PM
ksti's Avatar
It's called a center link, and yes that is your clunk noise.
Old Oct 1, 2012 | 09:28 PM
Luvmeye22re's Avatar
I'd call that the uberbrokenstein aka fix that before you wreck yourself! That thing has got to be broken in the center of the pin, or somehow it pulled up enough from the joint to make it look like that. It just isn't right and needs serious attention. That vehicle is not safe to drive like that IMO.
I know you don't know me but do me a personal favor and replace that and your idler arm before your truck veers off the road with the wheels pointed like this \ /
That is not safe brother
Old Oct 1, 2012 | 09:34 PM
ksti's Avatar
Kinda of a deceiving pic as the castle nut and cotter pin are still attached.
That's gotta be it.
Westly7's Avatar
Yeah my steering wheel been acting really crazy this past month on the highway
So i guess i need to replace center link and rebuild idler arm
Old Oct 1, 2012 | 09:46 PM
That's gotta be it.
Do you think it's broken or pulled 1/2 way out of the joint? I know for a fact that pin isn't that long....
I'd wager that if this was a 4x4 that thing would have let go and caused a ruckus on the road unless the upper (broken) half of that pin is seized into the link really well. It's still only a matter of time...
Old Oct 1, 2012 | 09:53 PM
Westly7's Avatar
Or maybe thats link for other truck fitted to mine by prev owner?
Its very loose/sloopy on pass side
On driver side has same lenght but tight wrapped by bicycle tube so its not loose/sloopy
Old Oct 1, 2012 | 09:54 PM
ksti's Avatar
I'm thinking it's broken inside the end of the center link and just hasn't popped out yet. Like you said it's a matter of time.
Old Oct 1, 2012 | 10:01 PM
Westly7's Avatar
Just opened rockauto.com for replacement parts but found bunch of brand from cheap to expensive,any recommendation which brand? Im pretty cheap btw
Old Oct 1, 2012 | 10:13 PM
Wrapped in bicycle tube? NOOOOO WAY! We need pictures of THAT abortion fix....
Back on subject. As far as parts go, you didn't mention any brands. I've had bad luck with Masterpro, will never buy a part of theirs again due to fitment issues right out of the box. Moog and Beck Arnley make suspension parts I dig on. They fit well and work well, and cost much less than original Toyota parts (although I have nothing against them, I CAN'T afford them).
Even being cheap in this situation, a used one from a junkyard would be better. I'd check out O'reilly auto if the are near you and go for Moog parts. They aren't too expensive, they aren't too cheap, they fit properly and they are pretty solid.
Old Oct 1, 2012 | 10:35 PM
Westly7's Avatar
as you requested pic of driver side with bicycle tube n ziptie
on brands there are kelsey-hayes,raybestos service grade,mevotech,acdelco,autoextra,moog,beck/anley,raybestos pro grade everything i order from cheap to expensive
i usually go with beck/arnley on my other car (240sx's and civic)
autozone was $58 plus tax
i can go hunting on auto salvage too
Old Oct 1, 2012 | 10:42 PM
No worries, I'm relatively cheap too I'd go with the beck arnley or moog. Neither will be that expensive and you'll know how old the part is. You will feel like a king driving down the road after you get that part in because it will drive so smooth. Don't forget to align the front end after you put it in, I bet it will be a bit out of whack I'd give the ball joints and tie rod ends a wiggle too, with THAT KIND of repair who knows what else is going on....
Old Oct 1, 2012 | 10:49 PM
Westly7's Avatar
Cool thanks for the helps imma ordering parts soon i did wiggle tie rods n joints they feel fine no play
Old Oct 1, 2012 | 10:53 PM
No problem. As stated earlier, please don't drive that thing! I don't wanna see you pushing yourself around in a little chair that you have to blow into to make it move. That thing is BUSTED and BROKEN and not safe.
Old Oct 2, 2012 | 06:22 AM
Pat8942's Avatar
I wouldn't worry about him, I worry about the innocent people he might kill.
Old Oct 2, 2012 | 07:22 AM
ksti's Avatar
I might get in trouble for this, but I'll take the chance. Your a sad angry person, your avatar fits you perfectly. The fact is your also the dumb ass!. If you don't want to help, then STEP OFF!
Old Oct 2, 2012 | 11:40 AM
Westly7's Avatar
Lol no need to argue or kill innocent ppl,went to autozone and spent about $270(include bunch of rent tools) and im halfway done to replace center link n idler arm
That links are bitch to pull it out
Old Oct 2, 2012 | 12:15 PM
Pat8942's Avatar
Yeh you just drive it like that you idiot,and BTW you are the dumb ass for even thinking of taking that piece of junk out on a public street.
Old Oct 2, 2012 | 12:16 PM
Pat8942's Avatar
Your's fits you pretty well too.
Old Oct 2, 2012 | 01:34 PM
Westly7's Avatar
Holy ˟˟˟˟ what the ˟˟˟˟ is wrong with u??
This is my thread my car so ˟˟˟˟ and gtfo!!! Im not asking ˟˟˟˟ from your smart ass
Mind your own bussiness,whore
