elocker pinion
Old Oct 1, 2012 | 05:52 PM
Mandy Tuning's Avatar
elocker pinion
i have a elocker from a 96 runner,want to regear but dont want to mess with the pinion flange to look if its 27 spline or 29 cause is my daily driver. nitro gear now are 29 splines and will be easier if i dont need to spend some cash on a pinion flange.any thoughts?
Old Oct 1, 2012 | 06:31 PM
BigBluePile's Avatar
Um....what?
Old Oct 1, 2012 | 07:01 PM
pinion splines,some are 27 splines ,some are 29splines, i beleive all elocker are 29 but not sure.
Old Oct 1, 2012 | 07:31 PM
And what exactly are you trying to do?
Old Oct 2, 2012 | 03:35 AM
want to change gears,but nitro gears already came 29 splines on the pinion. yukon are 27splines, you need to change pinion flange if your doesnt match on splines. i want the correct ones,seems elocker are 29,but not sure.
Old Oct 2, 2012 | 05:00 AM
waskillywabbit's Avatar
:wabbit2:
Old Oct 2, 2012 | 07:49 AM
no one can help?
Old Oct 2, 2012 | 08:54 AM
westjohns yota's Avatar
your best bet is too just pull the pinion flange off and count, if your regearing just buy a new flange anyways......
Old Oct 2, 2012 | 06:47 PM
I've never noticed the pinion spline count when upgrading elocker gear sets.
Old Oct 3, 2012 | 01:53 AM
vital22re's Avatar
totally a bro
Why don't you post a picture of what you're talking about willis.
Old Oct 3, 2012 | 04:55 AM
dropzone's Avatar
Fossilized
Your are gonna get a master install kit right or were you planning on using used bearing?
Old Oct 3, 2012 | 06:22 PM
If you order a r&p for an elocker it should be what you need.
Old Oct 3, 2012 | 06:59 PM
this came out from a 60k miles 4 runner that never used the elocker, so going to use a mini kit.
Old Oct 4, 2012 | 05:49 AM
Well good luck! You going to use a solid collar?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
digitalracer
May 16, 2016 03:57 AM
Odin
Sep 26, 2015 06:56 PM
justdifferentials
Sep 5, 2015 06:52 PM
