Oil pressure drops
Old Sep 14, 2012 | 07:11 AM
Yamiryder's Avatar
Oil pressure drops
My oil pressure has been fluctuating a lot recently in my 22re. I didn't notice is before i changed the oil, but since i've changed it, it seems to drop at low RPM, then go back to normal at around 2K-2.5K. I haven't messed with my spark plugs, cap, or rotor yet. I'm running 10w-30 and a pureone oil filter....should be what i'm supposed to be running. The truck seems to idle fine so that's what i'm not understanding. I'm also going off my stock oil pressure gauge.
Old Sep 14, 2012 | 07:19 AM
redbayredneck's Avatar
The stock oil pressure guage isn't completely accurate. If you do a search of the forum, you will also see that the 22re isn't supposed to have a lot of oil pressure at idle.
What pressure are you getting?
Marc's Avatar
normal
Old Sep 14, 2012 | 08:03 AM
Yamiryder's Avatar
ok, just wondered. I did search but i only found ones on the 3VZE
Old Sep 14, 2012 | 08:10 AM
xylicon's Avatar
It is normal, I have an auto-meter oil pressure gauge in my truck, when the engine is at operating temp and at idle I'm around 12PSI, when I am cruising @ around 2500-3000RPM I'm at 65-70PSI
Old Sep 14, 2012 | 09:15 AM
bjlambert's Avatar
Check out the oil pressure switch, and check for possible oil leaks
Old Sep 15, 2012 | 04:19 AM
Yamiryder's Avatar
Ok that makes sense. Oil pump spins faster as the engine turns faster. I just never noticed it before that's all.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
