Clutch fork floating??
Old Sep 22, 2012 | 02:32 PM
mldave's Avatar
Seems like my clutch bracket is good and a fellow pulled a rubber boot underneath the truck and said the clutch fork is floating.Guess this would explain the non/or hard shifting?How long to pull the tranny on my 86 Toyota truck 4x4 2.4 and check and repair this?Could it be the clips on the fork and is there a spring there?
Old Sep 22, 2012 | 07:35 PM
slow-mo's Avatar
Yes.
http://www.utoyot8.com/FullImage.asp...23%2c6%23..MTM
I'll let others chime in on the R&R of the transmission of a 4x4. I've done it on my 2WD.
Old Sep 22, 2012 | 07:45 PM
old fart's Avatar
Dunno if this will help
https://www.yotatech.com/forums/f120.../#post51699217
And on my 88 4x4, the starter removal was the worst part for me, then the 2nd worst was the two bolts at the top of the trans. When i did mine, i just took out my drivelines, supported the transmission/transfer case, undid the lines, wire connectors, and bolts,(undid everything) then undid the bolts on the crossmember, and dropped transmission/t-case as one unit. A tranny jack is an awesome tool to have, or rent, lemme tell ya.
Old Sep 25, 2012 | 06:22 AM
mldave's Avatar
My friend looked inside and saw metal particles and said it's likely from the throwout bearing,so I guess it's time for an Aisin clutch kit when money is available.
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
