ISR Mod on 3VZ-E?
Old Sep 29, 2012 | 11:51 AM
AdamP's Avatar
ISR Mod on 3VZ-E?
Hi there,
Can the ISR mod be performed on the 3.0 3VZ-E engine. I've done a search and only found info on the 22R-E and 5VZ-E engines.
I took the module off and had a look at it and it just appears to be a plastic box with a 90 degree turn it it.
Any help will be appreciated.
Adam
Old Sep 29, 2012 | 12:11 PM
MudHippy's Avatar
Click me.
Old Sep 29, 2012 | 12:14 PM
AdamP's Avatar
As I stated, I've searched, but not found an article that specifically mentions the 3VZ-E.
Old Sep 29, 2012 | 01:03 PM
AdamP's Avatar
I stand corrected. I only searched on here and didn't find. However, when you google it(as you kindly supplied) it throws up a thread, from here of all places. I guess the google search has more slack than the forum search.
So, thanks.
Old Sep 29, 2012 | 02:17 PM
MudHippy's Avatar
It is odd isn't it? Why the terms ISR mod 3VZ-E don't give you much using the search feature. As far as threads or posts are concerned. Yet if you click on Web & Images for those same terms, you get much better results. As far as what you were looking for, that is.
Old Sep 29, 2012 | 04:07 PM
AdamP's Avatar
Yes, I use the Pelican Parts forum a lot and same thing there. I guess these "off the shelf" forum solutions don't have a particularly sophisticated search engine.
Old Sep 30, 2012 | 04:25 AM
Pat8942's Avatar
Idiotic waste of time for absolutely no benefit.
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 10, 2015 09:01 AM
