High Idle, Then Dies
Old Sep 13, 2012 | 12:09 PM
BigSwole's Avatar
Ok so i have a 90 toy 22re and i cannot for the life of me solve this problem.
Its an auto so when in park or nuetral it idles high. Really high. Reason being when shifted into reverse/drive/ or any gear besides p or n the idles drops EXTREMELY LOW.
to the point where red lights and stop signs i shift into nuetral to keep it from shutting off. Even coasting to a stop it will sometimes shutoff.
It is also running rich.
My tps is adjusted correctly. I have just done plug, cap, rotor button, and wires wires.
Old Sep 13, 2012 | 12:11 PM
BigSwole's Avatar
My tps is adjusted correctly. I have just done plug, cap, rotor button, and wires. Air filter isnt a problem.
Im thinking about changing the 02 next but would like an idea which direction to head instead of throwing parts at it. Would like to find the issue and resolve it.
Where would you start? Need anymore info?
Old Sep 13, 2012 | 12:13 PM
Inferno451's Avatar
I'd start by checking for vacuum leaks. Hoses on the intake manifold, intake boot, etc. Spray little bits of starter fluid on areas you want to check, if the idle goes up you've found your leak.
Old Sep 13, 2012 | 12:16 PM
BigSwole's Avatar
Hey inferno i have checked and havent found a leak. I will check again but so far i havent found anything
Old Sep 13, 2012 | 12:19 PM
BigSwole's Avatar
Also had the timing checked and its good. So we can rule that out
Old Sep 13, 2012 | 08:13 PM
abecedarian's Avatar
adjust timing, idle, timing, idle...
with the transmission in drive.
engine AND transmission must be at operating temps too.
Old Sep 13, 2012 | 09:22 PM
Tried adjusting the timing and idle speed in "drivre"?
Old Sep 14, 2012 | 04:13 AM
BigSwole's Avatar
Engine and trans. Were in operating temps, but if i adjust idle while in drive when i shift to park or nuetral the engine reva really high.
It runs really really rich no matter what i do.
Old Sep 14, 2012 | 04:29 AM
Terrys87's Avatar
Undeneath the Throttle Body, there is a spring with a bulb like piece there, is it possibly holding the trottle open? Try to see if you can close the throttle closed/ slower at the linkage and see it if slows the idle down. Just wondering if the Throttle body is closing as far as it should. Try burping the system by raising the front end up and letting it cycle the thermostat a few times and get air out of the system. Have seen that cause idle problems. Try adjusting the valves for good measure.
Old Sep 14, 2012 | 04:37 AM
BigSwole's Avatar
It is, last year i took the whole intake off and cleaned it.
Old Sep 14, 2012 | 04:47 AM
Terrys87's Avatar
Dashpot was the name I was trying to think of. Have seen the Auxillary Air Valve cause problems.
Old Sep 14, 2012 | 05:20 AM
BigSwole's Avatar
Aux air valve and dashpot, ill give those a look as soon as i get home, is there any way to check these 2 parts out to ensure they are working properly?
What do yall think about the 02 sensor? Running extremely rich and rough makes me think to change it
Old Sep 14, 2012 | 05:33 AM
dropzone's Avatar
Fossilized
**DUplicate threads merged***
Charecter1
Nov 6, 2023 10:08 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kyletbert
Jul 17, 2015 11:39 AM
