Master Cylinder Part Question (pic)
Old Sep 29, 2012 | 02:55 PM
crownjewel's Avatar
So I will be replacing my master cylinder and brake booster soon. I have a 1986 1/2 ton Base model pickup. Most parts just show generic photos of their items not necessarily for the truck. So I'm wondering if this piece (circled) will be supplied with the master cylinder, or if I need to order this separately.
Update: I replaced both front calipers, main master cylinder (bench bled), and brake booster fully bled the system, and still having braking issues, I'd like to replace this lower proportioning valve, does anyone know an aftermarket supplier or original OEM number for this? Been searching with no luck.
Thanks in advance.
Old Sep 29, 2012 | 03:34 PM
slacker's Avatar
it is a seperate piece
Old Sep 29, 2012 | 03:45 PM
lobukbuild's Avatar
ditto
Old Sep 29, 2012 | 10:06 PM
crownjewel's Avatar
Thanks, but what is that part called please? And what does it do? Trying to look it up by name but don't know what its called.
Old Sep 30, 2012 | 04:02 AM
Pat8942's Avatar
Proportioning valve, it controls fluid pressure between the front and rear brakes. If it's not leaking or malfunctioning, there should be no need to replace it.
Old Sep 30, 2012 | 08:03 PM
crownjewel's Avatar
Originally Posted by 50r
Why this one has two most of the times its connected to the master cylinder
I would have thought so too, but I've seen other trucks with this same double component setup as me...weird. I'm now wanting to replace this separate valve and can't find an aftermarket one. Anyone have any leads?
Old Oct 1, 2012 | 02:49 AM
Pat8942's Avatar
No such thing as aftermarket for this part, if there is nothing wrong with it why replace it? But hey, it's your money, oh and BTW, all vehicles have this valve, it ain't nothin new. The part is around $180 at the dealer so you might want to rethink replacing things that you don't even know what it's there for.
bigjstang
Jun 2, 2025 03:56 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
