Fuel pump pressure???
Old Sep 25, 2012 | 04:42 PM
quiggs12's Avatar
Does anyone know if there is a difference between the fuel pressure range between and 87 and 88 4wd, 22re pickup? I have both the 85 and 88 FSM and see there is a difference between them...
My parts truck is an 87 and I pulled the fuel tank because my fuel pump bracket on my 88 is looking sad. However, my 87 looks good so I want to just put the whole tank and pump on the 88... Make sense? Thanks
Old Sep 25, 2012 | 10:49 PM
wyoming9's Avatar
Red face
Your talking about 2 fuel pumps and pressure from the same engine??
Either the 22rec or 3.0 your not talking fuel injection and carb engine??
Between the Carb engine very low pressure and the higher Fuel Injection pressures is where you would have a problem.
Old Sep 26, 2012 | 01:51 AM
quiggs12's Avatar
I'm talking about 2 trucks that are different years (87 and 88) both with the same engines... 22re.
Do the fuel pumps operate at different a psi? There is a difference between the 85 and 88. I just don't know if the 87 is like the 85 or 88, as far as psi...
Old Sep 26, 2012 | 03:35 AM
blazinbusa's Avatar
As long as both 22re engines are fuel injected you will be fine.
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
