PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 [111] 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 94 4Runner 3.0 stalls at idle when hot
  2. 22 re engine problems
  3. Code 31, hesitation, lack of power..diagnosis
  4. Finally Back in a Toyota!
  5. Fuel Pressure Tester
  6. Best way to test AFM
  7. major loss of power check engine light on
  8. Can't adjust engine speed down with the carb idle speed screw?
  9. Bought another truck!! :)
  10. 94 Pup died while driving
  11. AT shifting in/out of overdrive at operating temp? SOLVED
  12. Extra 4Runner Dome Light From Pickup (pics)
  13. ARB BUMPER Help
  14. Windshield interchange...
  15. Head/cam question
  16. No Power Windows, Moonroof, and HVAC problem?
  17. DOES any one have URETHANE CONTROL ARM BUSHING THAT DON'T SQUEAK!!!
  18. 93 Runner - 4x4 Indicator Switch
  19. My 3RZ Runs Great, Thinking About Supercharging it.
  20. my new toy!
  21. 87 4Runner 22RE engine wont pass 4k?
  22. to abs or not to abs
  23. (O2) oxygen sensor location on a 1988 3.0?
  24. solenoids, steering box, etc. I'm new to my yotatech and my yota!
  25. 1991 4Runner / overheating Transmission?
  26. rattle, clank, chatter noise - 95 4runner
  27. Rough runnings, intermittent miss at idle, jerks at take off, very descriptive
  28. 1993 SR5 timing problems?
  29. E-Locker into '94Runner
  30. coil to leaf question
  31. 7.5" differential assembly
  32. What T-case is this and what is it missing? (pix)
  33. First Off-Road Trip- Weird Trans issues
  34. Another transfer case/crawl box question?????
  35. Help me hook up my water temp gauge
  36. 1990 yota, non working speedometer... help?
  37. Fuel Electrical Problems - low voltage to COR
  38. Fuel pump keep the old or get new?
  39. rear driveshaft length question 1990 sr5
  40. Just a FYI day...Tune ups done right help.
  41. My 88 p/u O.D'd...
  42. 4runner surf diesel OEM Radiator
  43. Vacuum line?
  44. Fan support bolts stripped?
  45. missing lines!?
  46. ABS actuator removal questions
  47. What is this and how do I connect it?
  48. 1992 22re trouble code 52 help
  49. 1st Gen 4 runner harness help
  50. New Here Frame Question
  51. 86 22r carb, won't shift gears
  52. Whats the most weight you had in the back of your Toyota?
  53. 22re to 22r swap
  54. 91 Sr5 PU - Identify what I'm Missing!
  55. Need help with SR5 Gauge wiring
  56. Two Lower Oil Pump Bolts Leak
  57. Bushwacker Fender Flares/I need help!
  58. Fixing Leaks; Oil Pan on deck, Help :)
  59. 22 RTE vacuum line help
  60. 86 P/U Restoration Trans/Fuel Tank
  61. 3vze-22re
  62. 1990 4runner won't move in 2h or 4h only lo?
  63. Exhaust Valve Adjustment 94 V6 AT 4x4
  64. low shock absorbtion
  65. 4wd light not the norm problem
  66. gettin another toyota. few ?s
  67. Replaced EGR now wont start!!!!
  68. My new mall crawler / DD
  69. wierd vacuum hose problem
  70. injector wires crossed up how do i kno were they go
  71. Deer damage part identification problems
  72. Is my window motor dead?
  73. Pics of Yakima rack/Tire Carrier on my 1st gen
  74. 95 4Runner - hydraulic whine sound with clutch pedal pressed
  75. 22re rough start when hot
  76. exhaust gaskets/hardware help needed
  77. Gas tank reserve = 1 gal???
  78. 4runner wont engage 4wd!
  79. How do I change coolant temp sensor on 3.0
  80. 86 toyota pickup 22r vsv help
  81. Redneck Parking,... nope, a DUI.
  82. A/c Idenitfication?
  83. 3.0 v6 mixed up cylinder heads on rebuild. Dizzy wont fit; any fix?
  84. found two sets of buckets at the boneyard today...
  85. 94 pickup 22re misses
  86. R150F Clutch Release bearing clip, is this installed right???
  87. 22re miss
  88. electrical burning smell under hood
  89. idle keeps dropping
  90. Missing Bolts - Transfer to Transmission
  91. 92 4runner auto to manual swap....
  92. Wheres the EFI fuse?
  93. Help Identifying Parts Thread
  94. V6 + 4.7 = AWESOME - But watch that install
  95. Are similar PCV valves interchangable for my 22RE Rebuild?
  96. 2.5" rear lift, Locker switch, rear window
  97. 22re wireing trouble
  98. 3VZE cam bearing???
  99. Anyone ever looked into Roadmaster suspension?
  100. 4x4 ECM in a 2Wheel drive?
  101. NO cut ZUK spring options
  102. problems after headgasket replacement.
  103. Chassis Lube Visor Card
  104. 22re running EXTREMELY rich
  105. Alternator serpentine belt problems (loud squeal)
  106. wheel "popping" in and out when braking??
  107. 1988 toyota pickup trowing codes and no torque
  108. Low idle and low power
  109. ARB Bumper Hardware
  110. 1990 4X4 Truck Automatic
  111. No converter lockup at 60 and above.
  112. Main Bearing Insatllation Question
  113. 93 runner, Help, check engine light no codes
  114. guide me through timing a 22re with light
  115. Help new engine runs rough in gear
  116. Seat Swapping bench to buckets...
  117. distributor voltage at ecm? 3vze, crank but no start almost solved
  118. 4.88 swap increased MPG
  119. oil pump leaking
  120. Just swapped in another 22RE and need help
  121. ABS actuator diagram???
  122. 22re no start
  123. Timing, Valve Job, and Idle
  124. Any high-mileage Rock head gaskets? Time until retorque?
  125. A/T Transmission temp...
  126. Painted Taillights....
  127. Clutch Slipping (Needs Replaced?)
  128. Electrical trouble!!!
  129. Drive shaft part numbers?
  130. Transmission Installation - Tips/Tricks?
  131. Backlot Finds
  132. Ammo Can for Center Console
  133. Warning lights came on suddenly.
  134. Does LCE sell California spec headers for the 3.0 engine?
  135. How long for your 3.0 to come up to temp?
  136. Need brake rotor help?
  137. 87 4runner; clunking in front passenger side from 10mph+
  138. Orings for R134 swap
  139. Removing Factory Body Decals
  140. Introduction, Need advice and help
  141. Muffler In and Out Dimensions?
  142. Front wheel noise/vibration while braking
  143. where to get interior parts?
  144. Diagnosing the A/C
  145. 89 sr5 no start help needed
  146. 2ndary cooler
  147. 91 Pickup Sputtering From Water, But Unidentified Cause!
  148. Rear differential housing question ?
  149. PLZ HELP: Going to see SAS '91 4Runner - tips?
  150. tightening front wheel bearing
  151. Guide me through a tune-up
  152. Throtle stop screw
  153. PS stock cooler?? Unexpected find during swap
  154. Antena adjust.
  155. 1st gen roll bar
  156. Legroom
  157. Long Range (300 mi) Towing W/ 3.0
  158. Color Code
  159. Dual case question
  160. 12V outlet wiring options
  161. Towing capacity of my 89 4runner 3vze 5 speed
  162. ARB 3rd Gen Roof Rack on 2nd Gen
  163. 2wd v. 4wd Transmission
  164. 1st gen 4Runner Brake upgrade ??
  165. '87 rear window and wiper problem?
  166. Twin stick
  167. is there a short term reason for over tightening ILS bearing?
  168. What is this Whine in my 3.0?
  169. 33x12.5 Goodyear MTR Stock Wheels + No Lift = Possible?
  170. Fuel sending unit
  171. Rear Differential Drive Shaft Seal
  172. Where to buy tailgate internals?
  173. squeaking from front of engine in NM
  174. Groaning/Grinding noise coming from Drivetrain
  175. Slight brake fluid leak from piston
  176. missing cylenders during start up
  177. Turn signals and hazard lights.
  178. towing with 35s
  179. CEL on no codes
  180. CV Axels: Is this correct? (Pics)
  181. Idling high when in Neutral
  182. BlaZuk!! - installing Blazeland and Zuk stuff!
  183. My only regret with my zuk springs
  184. 4runner body swap??
  185. Is My Oil Pump Going Out?
  186. off road basket or carrier for 92 EX CAB - pics please
  187. 3.0 Diagnosing a Miss - Head gasket/Head?
  188. 91 22re started missing like crazy
  189. steering gearbox leak
  190. My Saggy Rear
  191. Big Thanks/header question
  192. 5speed
  193. Tell me what I'm leaking by these pics
  194. water causing engine lug
  195. 22re Hesitation/Idle issues HELP!!!
  196. Replacing both thirds
  197. front bumper part question
  198. Need help, Hissing Noise coming from Engine when vehicle is off
  199. Engine rough between 2k-3.3k-Help!
  200. Electrical fire... watch that battery!
  201. Need alittle help with 3vze!
  202. need help to ID transmission
  203. Parking brake front cable questions
  204. 92 22re fuel pump wiring
  205. Truck Shell and Tailgate on 4Runner?
  206. Truck smokes on inclines
  207. Where to buy fuel line with banjo type fitting?
  208. Small nick on my piston; is it still ok to use?
  209. UPS at the door!
  210. What's Causing the Rear Lift on my Truck?
  211. 88 P/U Irregular Idle?
  212. Help! shorted the wrong connector
  213. 1986 22rte:klacking at idle/when let of gas
  214. Unusual jerking/bucking
  215. 22re runs really bad when warming up then dies
  216. Name This Noise!
  217. Bad U-Joint?
  218. fuel tank swap
  219. where to mount speakers in rear?
  220. Rod Damage
  221. Need help ASAP! 3VZE coolant drain plug location
  222. Who's 4Runner is this?
  223. Truck vibrations at speed
  224. hey got 89 3.0 cold start problem
  225. Woot! not a head gasket
  226. Sound deadening tips needed
  227. Power Steering question
  228. My new 86 4runner... parts or fix up?
  229. Help with a "pulsing power loss"
  230. HELP. I need a measurement from you FROR Full Float Guys
  231. Clutch Master & Slave same for 2.4 & 3.0?
  232. 92 22re hesitation under load
  233. stock 89 tb bore
  234. Break in Used Gears?
  235. Knock Sensor, with no code?
  236. 87 22RE CAMPER - Runs choppy on startup, warm up runs good, no power when hot.
  237. recognize this transmission?
  238. Front end noise...
  239. Radiator, to be or not to be, replaced
  240. 22re Water Leaking Issues
  241. Bad Brakes (odd clunk + weird pedal action)
  242. transmission overheating, mechanics are stumped
  243. Burnt Piston Piston size
  244. rag joint/ steering coupler upgrade?
  245. Rear window Issues
  246. Speedometer Intermittent
  247. NEED HELP!!! Installed a header, Truck now runs like garbage
  248. No acceleration above 3500rpm
  249. Noise after Complete front brake job, like a "whistle"
  250. clutch master cylinder
