89 sr5 no start help needed
Old May 20, 2011 | 07:28 PM
iloveboost131's Avatar
I just recently bought a 89 sr5 with a v6 3.0 in it. I purschased it not running. As I try to start it, it turns over fine but does not crank. With a little shot of starting fluid it cranks right up then soon cuts off. I check the air filter and pulled the gas tank out and checked the fuel pump. As I turn it over it seems to be working. I'm stuck where should I trouble shoot from here.. Please help
Old May 20, 2011 | 08:40 PM
the_supernerd's Avatar
If it starts with starting fluid then you are getting a spark, so it is a fuel problem. Hook up a fuel pressure tester (you can borrow them from Autozone) and see what the fuel pressure is. Eventhough the pump works, it may not be producing enough pressure. If the fuel pressure is good, then it means the injectors are not firing for some reason.
marcusSRG
Jun 27, 2015 07:13 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
