22re wireing trouble
Old May 25, 2011 | 08:41 PM
89_yoder's Avatar
ok i just bought a 89 toyota with a 22re motor in it an i have mosts of the wires hooked up but they are 4 red wires that go into one what are they? My starter also clicks but thats it could the 4 red wires have something to do with that?
Old May 25, 2011 | 08:45 PM
justin_4runner's Avatar
can u take a pic and post what wires u are talking about, u will need to use photobucket and then load them up.
Old May 25, 2011 | 09:23 PM
89_yoder's Avatar
idk i can try
Old May 25, 2011 | 09:38 PM
89_yoder's Avatar
i cant get them to load up. but they are 4 red wires going into one end with a hole on it like it goes on something
Old May 26, 2011 | 01:27 AM
Bassmastry101's Avatar
Where is the wire your talking about located? A little more information would be helpful..or pics if you got them.
Here is a good guide to posting pics if needed.
https://www.yotatech.com/~corey/help.htm
Old May 26, 2011 | 10:15 AM
89_yoder's Avatar
the wires are below the intake on the left side. they come out of the wireing harness
Old May 26, 2011 | 04:32 PM
Are they white connectors? Going under the body right next to the starter? If that's it I believe those do go to the starter.
Old May 26, 2011 | 04:46 PM
swampfox's Avatar
Is it the ground wire that goes to the stud on the lower intake ?
Old May 26, 2011 | 05:03 PM
89_yoder's Avatar
no they are not white they are 4 red wires. swampfox im not sure but i did have them grounded but i took it off bc i didnt kno if they was a ground. i have got to get a starter bc mine just clicks. but if you all have pics of your wires i can tell u more bc i cant get my pics to load. thanks michael
Old May 26, 2011 | 05:15 PM
If you want to email me your pics i'll gladly post them up for you
Old May 26, 2011 | 05:38 PM
swampfox's Avatar
I went and looked at my 89 and the ground that I was talking about has a square shaped connector with a hole a little bigger than a pencil. The wires are grouped two in one connector on one corner and mine has one wire on the other corner same side. The wires are a reddish /orange color.
Old May 26, 2011 | 06:15 PM
89_yoder's Avatar
ok whats ur email. thanks again i think we are talkin about the same wires
Old May 26, 2011 | 07:13 PM
pm sent
Old May 26, 2011 | 07:48 PM
89_yoder's Avatar
ok thanks
Old May 26, 2011 | 08:03 PM
Got the pic and I blew it up a little so we can see it.
It looks to me like the ground that goes to the intake...I didn't have mine hooked up and my injectors weren't working and it would just turn over..Maybe someone else can shed some light on it.
You could always turn the ignition switch on and check for voltage just to be sure its not hot before you ground it.
Old May 26, 2011 | 08:27 PM
89_yoder's Avatar
thanks.
MO transplant
Apr 23, 2023 11:58 AM
Doug4320
Mar 24, 2018 10:11 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
bryan34w
Jul 6, 2015 05:53 PM
