help please yota bros! A link or form! 95 4runner brake rotor
Old 05-10-2011, 04:43 PM
offroad1990's Avatar
I gota change my front left rotor out, on my 95 3vze 4runner but not to sure how with this one, any forms or info with pics at all??,, thanks, jesse
Old 05-10-2011, 05:27 PM
kaner07's Avatar
your gonna have to take everything off the axle shaft. take the dust cap off the end. Remove the 8 or so bolts that hold the end cap on and slide it off. then there is some clips and large nuts and lock clips that you need to remove then you should be able to slide the rotor off. then you need to seperate the rotor from the hub by taking the bolts on the back out. then you will probably need to beat them apart with a hammer and a chisel. hope this helps good luck
Old 05-10-2011, 06:25 PM
toyota4x4907's Avatar
http://www.ncttora.com/fsm/1990-1995...es/repair.html
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: help please yota bros! A link or form! 95 4runner brake rotor
