7.5" differential assembly
Old May 31, 2011 | 10:41 AM
Utah4Runner86's Avatar
The long-side gear shaft - how does it seat in the differential tube? What keeps it in place? I've got a FSM and a Chiltons, and neither is much help.
Old May 31, 2011 | 12:01 PM
BigBluePile's Avatar
I think its a c-clip.....
Old May 31, 2011 | 12:46 PM
The MAN's Avatar
I don't think there's any axle clips in a 3rd member setup... the bolts at the end of the axle tube holds the axle shaft in place
Old May 31, 2011 | 12:51 PM
Aww, booger. Ok, I think I found it, there's a slot that looks like it might want a c-clip, right on the tip of the spindle where it meshes with the diff.
I'm going to have to open the diff to install that thing, aren't I? I was really hoping to not need to do that.
Old May 31, 2011 | 12:53 PM
I do know theres a c-clip on the stub shaft and am pretty sure there's one on the long shaft....
Old May 31, 2011 | 01:03 PM
...technically, I think it's called a snap ring....
Old May 31, 2011 | 01:40 PM
AxleIke's Avatar
It is absolutelt a c clip or snap ring, whatever you want to call it. Both shafts use that on a non add set up.
Old May 31, 2011 | 02:38 PM
bynder's Avatar
No u don't have to pull the diff to do this. And yes there are clips on both the short and long shafts. Just pull the axles out, put the clip on and push the axle back in.
Old May 31, 2011 | 02:41 PM
Thanks, guys. I'm dreading the answer to this, is there any way to install that clip without disassembling the gears? I've got the front cover off, and I don't see any way to make that happen. I'm trying to avoid paying a shop, but I don't have tools or the knowledge to set the gears up again if I take them apart.
I love simulposting. Does the clipped shaft just kinda snap in, then?
I apologise for all the questions, but I haven't done this before, and this loaner diff came to me with the longside shaft loose, so I'm stumbling around in the dark here.
Old Jun 1, 2011 | 02:51 AM
bynder's Avatar
Yes it just snaps in
Old Jun 1, 2011 | 02:58 AM
Huh. Allrighty then, I've got the c-clip on order from the dealership, so this sounds to be easier than I was fearing for a bit there. Thanks for the help!
Old Jun 1, 2011 | 06:11 AM
meisentones's Avatar
I apologize about the thread jack, however I have a question about this.
I am going to be pulling an ADD from the IFS third and replacing it with a non-ADD. To pull the axles out, do I just unbolt, or will I have to pop into the differential to get access to this "clip"? I realize you said it will just pop in, but will it just pop out too?
Thanks!
Old Jun 1, 2011 | 08:55 AM
bynder's Avatar
Take a long handled srcew driver and pry between the axle and the housing, comes right out.
punks_is_4x4
Feb 26, 2016 04:29 PM
voiddweller
Oct 2, 2015 07:47 AM
LCE_Performance
Oct 1, 2015 01:03 PM
tylermx71
Sep 29, 2015 08:49 PM
Odin
Sep 26, 2015 06:56 PM
