91 Pickup Sputtering From Water, But Unidentified Cause!
Old 05-20-2011, 02:51 PM
Rickolition's Avatar
Hey yota lovers, I've got a serious problem!
Whenever I go through small bodies of water that are 6" deep or above (amount of water splashing), my truck starts to sort of sputter, like when I try to accelerate, it mildly jerks but I have no power at all. This will last a few minutes and then be completely fine! It only has started to do this about 2 or 3 months ago.
note: My distributor is already waterproofed, and it mostly happens when I go through puddles on the right side of the truck.
I need serious help, or else I may be without off-roading this summer!!!
Old 05-20-2011, 04:09 PM
Please everyone, I really need some help and have been fighting this problem for a really long time. I could fix whatever is wrong, if i knew
Old 05-20-2011, 04:17 PM
Teuf's Avatar
Seal the new cap and rotor you should buy. Look at the spark plug wires at night to see if there arcing. And or get new ones. sounds like water is splashing up some. Make a splash shield.
Old 05-21-2011, 07:15 AM
The cap and rotor and completely fine, they arnt the problem. And I would create a splash shield but I just don't know what the problem is. My Plugs and wires are fine also, I did the spray test with them and I'm already using di-electrical grease on them.
Old 05-22-2011, 04:45 PM
Badger62811's Avatar
Give us some pics of the engine compartment, exterior driver side, and some of the driver side wheel well to give us an idea of what we're working with here. We might be able to give you a general list of "problem" areas.
Old 06-01-2011, 10:53 AM
73pinto's Avatar
ive always had problems of water hitting the igniter and causing sputtering check that out most likely the problem.
Old 06-01-2011, 10:56 AM
blake.nemitz's Avatar
why not pop the hood and have a buddy jump in and rev the motor, then while wielding a super soaker go to town until you find the short.
Old 06-01-2011, 12:22 PM
Bojangles's Avatar
If im correct, your saying that when you hit water on the passenger side of the vehicle, You lose power...
If your truck is anything like mine was, when you press the pedal full throttle during this problem, it takes off like a bat out of hell...
Your computer is behind the kick panel on the passenger side, Above and behind the dash there is a rubber grommet that is used to plug the firewall...After a period of time this grommet will get old and worn and begin to let water seep in, Thus leaking onto your computer.
At least this was my problem...
To get to this grommet, you will need to remove your windsheild wipers, Remove the panels underneith and you should see it on the passenger side.
Seal it up with some kind of liquid nails or 5200 marine adhesive sealant (amazing stuff)
Good luck!
Old 06-01-2011, 12:31 PM
The MAN's Avatar
make sure that COR relay is nice and water proofed too
Old 06-01-2011, 01:22 PM
tim a.'s Avatar
unplug large connector by throttle body and add dielectric grease.
Old 06-01-2011, 01:28 PM
Staff
DeathCougar's Avatar
Stop driving through water?
6" Of water isn't enough to get up near ANYTHING engine or electrical related.
Old 06-01-2011, 02:04 PM
tim a.'s Avatar
it is when your doing 20 miles per hour
Old 06-01-2011, 02:32 PM
Staff
I would think a reasonable person would have enough common sense not to go bombing through water at 20mph, regardless of how deep it is.
Old 06-01-2011, 05:57 PM
tim a.'s Avatar
Reasonable people dont spend hard earned cash on 20 year old trucks.Or ride 4 wheelers .Or race motocross,or drag race or own a machine gun.Reasonable people probably wear helmets in the shower because its such a dangerous place.Guess I must not have as much common sense as a resonable person,but I do enjoy myself.But if it scares you to hit 6 inches of water at 20 mph then my front seat aint the place for ya
Old 06-02-2011, 04:03 PM
Alright it's probably more around a foot or more of water, just in the rut on the side of the roads. but 20mph? thats idiotic.
But when I floor it it doesn't do that, it just has random surges of acceleration and the engine rpm's go wayy down (at least it sounds like it, my 91' doesnt have a tach). Sounds almost as if it were struggling to stay alive.
Old 06-02-2011, 07:09 PM
Staff
Sounds like a short then. But like a said, even at a foot nothing should be hanging down that far that will affect how it runs. I have had water to the bottom of my door (all the way over my 33" tires at the time" and it was fine
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 91 Pickup Sputtering From Water, But Unidentified Cause!
