Front end noise...
Old May 12, 2011 | 03:22 PM
green9422re's Avatar
Front end noise...
I have a 94 pickup and everytime I back out of a spot or back into a spot and I am turning my wheel, I get noise coming from the front end. It kinda sounds like grinding and a pop every once in a while. I have looked underneath the truck and everything and cant find anything thats rubbing against each other to figure out the grinding noise. Any thoughts/help would be greatly appreciated.
Old May 12, 2011 | 03:29 PM
metalhed's Avatar
steering stops. Searching will help you find the answer
Old May 12, 2011 | 04:23 PM
Mr.Utah's Avatar
Every old Toy I have had has steering limitations followed by that pop sound. The only way I have dealt with it is not to crank the wheel all the way to one side, give it a little slack.
Old May 13, 2011 | 02:24 PM
Badger62811's Avatar
Every Toyota truck and 4runner I've ever heard has that horrible noise. It's not always if you crank the wheel, but if you hit a bump and get the truck rocking side to side with the wheels turned a little bit. Mine sounds horrible and in the right area, echoes off of all the surrounding buildings. I get some weird looks from people.
Old May 13, 2011 | 04:45 PM
c12jockey's Avatar
I have a '92 that makes a squeaking noise in the suspension. Any ideas of what it is? I know about steering stops and it's not that. spraying lube on what parts I can access helps for a while but it always comes back and makes the truck sound like a hoopty.
Old May 13, 2011 | 04:56 PM
raddude666's Avatar
all ive ever heard is the steering stops but welcome to yotatech green9422re and c12jockey
Old May 13, 2011 | 07:09 PM
metalhed's Avatar
ball joints is next if it is a squeaky noise
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
