What is this Whine in my 3.0?
Old May 18, 2011 | 05:14 PM
B4Runner's Avatar
This sound is horrible. I have an aftermarket exhaust on now, and when idling, you can hear the whine over the exhaust. When sitting in the driver's seat revving the engine, you hear the whine over the exhaust.
(You can't hear the whine at first. Wait until I reposition the camera away from the fan and more towards the side of the engine bay. The video does perfect justice to the sound.)
Thanks to all that help!
http://www.youtube.com/watch?v=diNMqddzM4U
Last edited by dropzone; May 18, 2011 at 10:29 PM. Reason: eliminated double video link
Old May 20, 2011 | 11:21 PM
B4Runner's Avatar
OCDropZone, I believe now would be a swell time, as well as last time, to ?
Old May 20, 2011 | 11:52 PM
dropzone's Avatar
Fossilized
yes, but you didn't need to bump you own thread 5 hours and 7 minutes later...
Old May 21, 2011 | 12:01 AM
The MAN's Avatar
sounds like either power steering pump whine or alternator bearing noise to me
what is the fluid level and the condition of it?
Old May 21, 2011 | 09:57 AM
bugs1961's Avatar
Does sound like the PS pump--usually heard on Fords.
Old May 21, 2011 | 11:54 AM
oldblue's Avatar
remove your belts one at a time then run it to see if the noise goes away. if not, i'd say one of the timing belt idler/tensioner pulley bearings is shot.
Old May 21, 2011 | 12:18 PM
cman1's Avatar
i agree with oldblue...bumperoooo
Old May 21, 2011 | 12:54 PM
Team420's Avatar
yup... oldblue nailed it... one belt at a time, till u narrow down where its coming from
Old May 21, 2011 | 02:36 PM
sb5walker's Avatar
As others have said, something in the front. Candidates include power steering pump, alternator, fan bracket idler, A/C idler, or as oldblue pointed out, could be upper or lower timing belt idler, or even the water pump. Best tool for finding something like that is a mechanics stethoscope. They're cheap, available at any discount auto parts store. They have a long metal rod that you hold against what you want to listen to, and you can hear real well what the bearings sound like. You'll hear noise even from good bearings, but if a bearing is bad it's real obvious as the noise is terrible. Obviously, you have to be very careful keep the stethoscope, loose clothing and hair away from the moving belts. Running belts can grab things with stunning suddenness and violence. If you don't hear anything from the bearings in the fan belt area, more probably a timing belt idler.
Check your P/S pump fluid level 1st. You do use Dexron-rated ATF in there, right?
95blackToy's Avatar
Or you can hold a screwdriver on one of the pully bolts while its running and put it up to your ear and see which one is loudest.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
mtrdrms
Sep 26, 2015 07:12 AM
