Antena adjust.
Old May 19, 2011 | 07:25 PM
PR_TRUCK's Avatar
Antena adjust.
all what appear was cb radios antenas in the search. The base where the antena mounts its getting loose. Do i have to remove the fender to adjust it? Its a 88 Pickup sr5. Thanks guys in advance!! ps im trying to figure how to upload pictures...
Old May 19, 2011 | 07:28 PM
PR_TRUCK's Avatar
One more thing, when i turn the High light, the lights will go of but I just flash they work. The low lights works fine. Any clue on this? it cant be fuse because the hi function when I flash.
Old May 19, 2011 | 08:03 PM
weaselman's Avatar
its a switch problem.
and no you dont, you have to take the inner wheel well out. not the whole fender.
Old May 19, 2011 | 08:19 PM
4Crawler's Avatar
If it is like my '85, trivial fix:
- http://www.4crawler.com/4x4/CheapTri...acement/1.html
Or the bolt inside the fender may be loose:
- http://www.4crawler.com/4x4/CheapTri...acement/5.html
Old May 19, 2011 | 09:01 PM
PR_TRUCK's Avatar
Thanks 4 crawler!! I read you are electrical engineering, i am 4th year mechanical. There is a way to resolve the HI light problem, can be some contacts oxidated?
Old May 20, 2011 | 05:49 AM
4Crawler's Avatar
You bet, common problem and easy fix:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old May 29, 2011 | 02:50 PM
PR_TRUCK's Avatar
An update, the mast of the antenna is broken and I try to fix the high lights, but dint work. Would be better to replace the antenna with a aftermarket one with a low profile or should i buy just the mast or an complete used antenna in ebay?
Old May 29, 2011 | 03:11 PM
justin_4runner's Avatar
u can do a mask but when u go 4wheeling u could end up busting it off if u forget to turn off the radio, and with the headlight u might just need to replace the whole combo switch.
Old May 29, 2011 | 03:53 PM
wii_tarded's Avatar
You could do this approach... It's a rubber mast and I used an extension cable ($4.00 @ autozone)
Old May 29, 2011 | 03:59 PM
weaselman's Avatar
does your reception increase?
Old May 29, 2011 | 05:34 PM
wii_tarded's Avatar
I can't tell any difference. The truck never had an antenna from when I got it. I had tried to mount it to the fender, and hated the way it wanted to lean out to the side. So I got this bright idea, and haven't had any complaints.
Old May 29, 2011 | 06:19 PM
PR_TRUCK's Avatar
Does toyota sell only the mast?
Old May 29, 2011 | 06:21 PM
yes they do for about 50 bucks or so last time i looked. not sure of the price now tho.
Old May 29, 2011 | 07:50 PM
sebastianholmes's Avatar
yea you dont wanna break an antenna off. it sucks. goota replace the whole thing, unless you can find a way to get the threaded part out, i tried EVERYTHING i could think of. and dont buy one of those autozone ones if you want it on the fender. pissed me off so much cause it leaned so i layed it across my dash for like a month till i got a toyota one. friggin narrow trails!
markf1
Sep 3, 2015 01:23 AM
Matt02
Jan 8, 2008 01:56 PM
yotasavg
Apr 14, 2007 06:18 AM
lanai
16
Jul 12, 2005 05:32 AM
tomus1000
10
Jan 6, 2003 07:56 PM
