Missing Bolts - Transfer to Transmission
Old May 26, 2011 | 07:50 PM
RSuper's Avatar
Does anyone know the bolt size for the transfer case to transmission mount? I am looking for the actual bolt dimensions not the nut size (14mm). I reinstalled my transfer case and noticed that I am two bolts short. I scoured the garage but they are no where to be found. However, I'm pretty sure they were missing before I removed the transfer.. That, or I'm losing my mind.
Edit - I suppose I should mention what my truck is. Forgot I don't have a signature. It's a 91 Pickup 3vze 5 Speed.
Old May 27, 2011 | 10:02 AM
Link182's Avatar
your talking about where the transmission mates to the t-case right? the bolt is a 14 mil i believe. if im wrong and your unsure, i would call your local toyota dealer, and get the bolt size from them.
Old May 27, 2011 | 10:11 AM
xxxtreme22r's Avatar
why not take one of the bolts that you do have out and match it up? Not sure if they are all the same size and length but I am sure one of those bolts you have in there matches with 1 or both of the missing ones.
or go to the dealer and buy new ones.
I believe the part number for those bolts (9 I believe) is 90119-10019 this is assuming you have a w trans and a 4cyl, I have no clue what you have other then a 91 4x4 ext cab 5sp pickup since in all your posts nothing is mentioned.
Old May 27, 2011 | 02:37 PM
RSuper's Avatar
I would take one off and find a match but I won't have access to the truck until this weekend. I wanted to try and prevent having to make a trip back into town.
I appreciate the help. Pretty stupid of me to not post what my truck is. It's 3vze with a R150F. I'll more than likely just pull one off and go find an equivalent at a hardware store.
Old May 27, 2011 | 03:31 PM
wyoming9's Avatar
Smile
They are M10 x1.25 not real sure how long but I would guess 40 or 50 mm I think there are some that go into blind holes so you don`t want them to long
The M10x1.25 can be hard to find in some areas most have Din Bolts but not the JIS which is japanese Industrial Standard .
That is a standard size bolt on there trucks so If you buy extras you will use them
Old May 29, 2011 | 02:56 PM
thrice's Avatar
M10x1.25 40mm is the right size just did this swap a couple of months ago. Try Lowes thats where I got mine I think.
Old May 29, 2011 | 04:27 PM
waskillywabbit's Avatar
You are wrong. They are M10 and ALL bolts are sized by the DIAMETER not the head.
They are relatively cheap at the dealer and they will be the right length. I bet they are as cheap or cheaper than Lowe's and I doubt your local hardware store has the right grade anyway.
:wabbit2:
Old May 29, 2011 | 10:12 PM
wyoming9's Avatar
Red face
Wabbit not just Metric bolts are sized that way ALL bolts are sized that way.
Where did this bad habit of calling a bolt by the size of the wrench ever come from.
I must agree Toyota has real good prices on bolts
Old May 29, 2011 | 10:50 PM
The MAN's Avatar
Originally Posted by waskillywabbit
Metric bolts are sized by the DIAMETER not the head!!!
:wabbit2:
isn't that what he was asking for?
getting the right size is one thing, but getting the correct tensile strength is another story
personally, I'd just get the bolts from toyota and be done with it... hell, if I'm lazy and don't want to go anywhere, I'd just order online and have them shipped to me door
icentropy
Sep 16, 2020 02:47 PM
dumpster84
Apr 30, 2016 06:03 AM
Gone Fission
Jul 24, 2015 12:49 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
crashburnoveride
Jul 10, 2015 06:39 AM
