EGR plate still leaking
Old May 11, 2011 | 07:55 AM
Andrew Lam's Avatar
So I finally got the gasket for the egr plate, got it on, and after running the truck I'm still leaking. Not as much, and it stopped about a minute after shutting the truck off, but now I figure I have to take the plate off and apply some RTV. Wishful thinking that I wouldn't need it.
How should I apply the sealant? Both sides of the gasket? Around the bolt heads?
Will the Napa high-temp RTV I work?
Thanks.
Old May 11, 2011 | 08:19 AM
blake.nemitz's Avatar
i would use jb weld if you wont take it off again rtv might blow out if it gets hot enough.
Old May 11, 2011 | 08:40 AM
James Woods's Avatar
I have seen that high temp RTV used as exhaust manifold gaskets and it seemed to work just fine, I have never personally used it just seen it on cars that came in to get work done.
Old May 11, 2011 | 10:56 AM
MudHippy's Avatar
I've used ultra copper RTV on all my exhaust gaskets, except the manifold to head gaskets. It works fairly well.
However...
You shouldn't use RTV/FIPG on a 3VZE EGR valve gasket. Because the cold start injector is positioned so that it sprays fuel almost directly at it. RTV/FIPG and other silicone based sealants are not gasoline resistant(should not be used where it may come into contact with gasoline).
You should use a gasoline resistant sealant instead in that case, of which there are many.
See here.
jasonty
41
Dec 23, 2018 01:00 PM
montanatruck
Jul 25, 2015 03:45 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
