coil to leaf question
Old May 31, 2011 | 11:03 AM
73pinto's Avatar
i have a 95 limited with 4 wheel abs . can u still use my rear axle or do the 95 pickups have the 4 wheel abs. also if i find a pickup at the local junkyard can i cut the leaf mounts out and weld them onto my frame
Old May 31, 2011 | 11:57 AM
DeathCougar's Avatar
None of the pickups ever had a 4wheel ABS option. You have to use your axle if you wish to retain ABS.
I would get new leaf mounts rather than trying to cut used ones off and end up with crooked junk. Suspension on a road driven vehicle generally needs to be pretty precise.
Old Jun 17, 2011 | 10:15 PM
bcg1's Avatar
The axle housing from the 95 pickup will work fine if you use your third member with the ABS sensor. That would be the easy way. You could also your your current housing and buy aftermarker spring perches to weld on.
Either way you want to make sure you end up with the correct pinion angle but you knew that, didn't you?
Old Jun 17, 2011 | 10:31 PM
He has 4 wheel ABS, which puts a sensor at every wheel. NOT just on the rear diff. So, as I stated, the axle housing from the Pickup will NOT work if he wishes to retain ABS
88sasturbotoy
Jan 30, 2026 01:57 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Numberonedad6
Jul 30, 2015 07:10 PM
Nickdigg
Jul 7, 2015 06:04 AM
