water causing engine lug
Old May 16, 2011 | 01:49 PM
gymnast's Avatar
i have a 88 pickup, 4WD 22 RE EFI, whenever i drive through a stream and water splashes up into the undercarriage and engine, or if i spray out the bottom of the truck, and then i drive and the engine shakes and lugs real bad, it feels like it wants to die, then maybe half an hour later it works fine. where is the water going to cause this? any ideas?
Old May 16, 2011 | 04:13 PM
Sportsmanphil's Avatar
More than likely your plug wires/coil wire is causing your issues. Idle the engine and spray the wires down with a spray bottle, see if it acts up.
Old May 16, 2011 | 04:54 PM
blake.nemitz's Avatar
ya your getting your cap wet and its arcing in there. a little silicon around the seam of the cap and pack the plug boots with di electric grease and you should be good, hopefully
Old May 16, 2011 | 04:56 PM
WHEELER8688's Avatar
yep, mine does that too, probably water getting into the spark plugs or distributer, but it eventually goes away and runs fine.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
