Burnt Piston Piston size
Old May 12, 2011 | 08:11 AM
taylorham5842's Avatar
I have a 94 pickup with a LC engineering 22re w/ 40k miles. Bought it off a buddy a while ago.
Problem #1. I pulled the head off beacuse I found antifreeze in my oil.
Problem #2 SO inspecting the block I found the #1 piston had a 3/4" long piece missing on the outside. I could see the ring easily. Lots of carbon build up on piston and head. Very light scoring or cylinder. Now someone told be that piston might of burned up from too much fuel being dumped into #1 cylinder or timing advance to far.
Now measureing the piston i removed it is 3.683 or 93.54mm. Stock is 92mm right? So mine is bored over .060? I havent miced my cylinder yet but will today.
Got some work to do....
Old May 12, 2011 | 11:02 AM
The MAN's Avatar
could be a 94mm bore
Old May 12, 2011 | 11:54 AM
MudHippy's Avatar
94mm = 3.7007894", so no, it couldn't be. 3.683" = 93.5482mm, so 93.55mm is closer to what it really is(which it isn't). LCE calls them 94mm forged pistons...but they're not really though(obviously).
And it's also bored atleast .061"(1.5494mm) over. Stock is 92mm(3.6220492") + .061"(1.5494mm) = 3.683"(93.5482mm). But if you leave room for piston to cylinder clearance the bore should be ~3.684"(93.5736mm), so it's probably closer to bored .062"(1.5748mm) over in reality.
The engine is supposedly a 2.5L according LCE. But if the bore is 3.684"(93.5736mm) x 3.5039389"(89mm) stroke = 149.39698547055744 CID = 2449.1309093534004 cc = ~2.45L
Oh you want to know why the piston blew up, that I don't know. Might have something to do with the design, or install process, of the pistons. Seen something like it happen not too long ago with somebody's Keith Black pistons. I'd atleast want to know who makes these pistons myself.
EDIT: Displacement calculation revisions: bore & stroke = 3.687"(93.6498mm) x 3.5039389"(89mm) = 149.77279322747282 CID = 2455.2916922536528 cc = ~2.46L
Old May 12, 2011 | 03:54 PM
Thanks for the reply. Cylinder is about 3.687. but thanks for the helping me understand it better.
Old May 12, 2011 | 03:57 PM
Anyone know if wiseco 94mm pistons would fit? used them for years in my dirtbikes but never a car...
Old May 12, 2011 | 05:10 PM
MudHippy's Avatar
As far as I can tell, no they won't. Not without boring + ~.015"(~.381mm) over.
3.701"(94.0054mm) piston size
+ ~.001"(~.0254mm) optimal piston to cylinder clearance
~3.702"(~94.0308mm) optimal bore size
- 3.687"(93.6498mm) current bore size
~.015"(~.381mm) difference in bore size
BTW 3.687" - 3.683" = .004" and is considered excessive as far a piston to cylinder clearance specs. The FSM states it should be .0005"(.015mm)-.0014"(.035mm), or ~.00095"(~.025mm). If those really are correct measurements the pistons are a mismatched size, and that's what caused the failure.
EDIT: bore & stroke = 3.702"(94.0308mm) x 3.5039389"(89mm) = 150.86045741016092 CID = 2473.1222526255892 cc = ~2.47L
Old May 12, 2011 | 05:13 PM
xxxtreme22r's Avatar
Why not just take the engine to a machine shop and ask them. And with the broken piston I am sure your gonna have to bore an additional amount.
Old May 12, 2011 | 07:02 PM
engineshoppa's Avatar
Could you see the ring from the top with the piston in the cylinder?
Pics?
Old Jun 23, 2011 | 07:09 AM
Did take it to machine shop. Honed it a bit. there was no real damage thank god.
Old Jun 23, 2011 | 07:12 AM
I also talked to LCE. They said it wouldnt be a good idea to bore it over any more. I got new KB pistons and they work just fine.
Old Jun 23, 2011 | 02:49 PM
peow130's Avatar
Disagreed. Evidently theres a guy out at our racetrack with a 22R in his subaru (yes, subaru), running a 4" bore, with chevy pistons.
But hey, LCEngineering knows everything right?
Old Jun 23, 2011 | 03:31 PM
Agreed... The more I work on Yotas the less I believe in LC. They weren't to knowledgeable but they did try.
calderp
Nov 16, 2015 02:49 AM
old87yota
Sep 9, 2015 12:39 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
