- 1992 4Runner 4X4 HELP!
- Lifted pictures please
- push bar
- 86 22re Timing & Idle Question
- runner hood
- Spindle install help
- 22rte to 22re swap
- Easiest Way to get Lim. Slip or Locker in my 2WD Auto?
- WANTED: ARB, TJM, or other winch Bumper for 91 P/U
- 22r Stumbling on highway
- Worn input shaft
- fuel filter
- Rebuild: No Check Engine Light, Help.
- CV shaft Retainer Clip and Washer
- throwin a code
- Where is the T and E terminal for timing and computer check?
- Driveshaft precautions.
- upper control arm movement
- Picture request; STOCK '90 xtracab 4wd
- Tps Woes.........NEED HELP PLEASE.
- rear engine oil leak?
- glasspack
- does anyone
- 91 4Runner XFer Case Problems
- engine/trans work... easier to remove body off frame?
- 86-95 year model get together?
- temp gauge fluctuating
- Turn key and click!!!
- you have to lube so you can get in
- Strange 3VZ-E idle...
- synthetic, oil pressure, drip, frozen buns and anti-freeze fried chicken
- New Radiator installed, removing antifreeze smell?
- can i convert my truck
- 88 toyota timing problem
- Installing new kick down cable
- Snow Pics, pic heavy
- 22RTE Turbo
- If the owner can't tell, don't bother doing it.
- Too much blue!
- Running lights turn on under their own will
- motor cuts in and out while offroad???
- losing brake fluid
- anyone running a spool in the rear?
- Budbuilt plate. HOLY SMOKES!!!!!
- Ifs/ Rear stuff
- new transmission will this fit
- hubs?
- My 1998 4Runner has started to vibrate
- EngineRebuild
- Window Fuses?????
- Sweet 88 low rider
- thermostat and surging problems
- 83 Door Glass
- What is this?
- alternator belt extremely irritating
- coolant temp sensor goes to ECU or gauge??
- Cracked Radiator this morning, freezing cold
- Not my month 22re dead
- 90 4runner runs intermittently
- No 4wd below freezing
- Just got the truck, i have some ?'s
- 88', the front a/c sticker plate thingy...
- has anyone done a weber carb conv.?
- looking for a nice rear bumper with built in class 3 hitch
- 3VZE Heater hose connections
- Still more wiper issues
- how do I- I.D. a used locker without the p/n.?
- Help Me Plezz :)
- New Cold Weather Noises
- 33x10.5 on stock 86 4x4?
- body lift install question.
- ok heres a thought!!
- Old vid
- Rock Solid 4x4 Humboldt- Check this truck!!
- hood release cable broke!
- Very High pitched whine
- power band on a 22re?
- Too Much Ground??
- Qs about autometer water temp. gauge
- Non Reclining Suspension Seats
- bucking when in low gear and low speeds
- So Here in washington
- Injector seals
- Fuel rail leak, banjo bolt? and another Q.
- 22re piston movement--normal?
- seat swap?
- Freezing Cold Issues
- First Time Out In The Snow!
- Seafoam showed me an exhaust leak.
- MPG went down :(
- 1992 Toyota Pickup 4x4 Indicator Light
- Whirr whirr whirr whirr
- nubie
- marlin crawler rear bumper question
- quarter panel help!
- Strap plus radiator
- mud terrains on snow???
- My latest Craigslist find.
- 37-13 R15s on SAS Pics
- quick block heater question
- Please give your opinion..
- 2wd Turbo pickup??
- SS IFS brace..... is it needed?
- Throttle issue
- i need help timing a 86 pickup
- running a block lift in the back need advice on leaf spring lifts
- Fuel pump issue
- Advice on a 3VZE rebuild
- Best headlights
- truck pulls one way and shoots other when off gas! LSDs
- Installing engine tomorrow, need help
- Engine blown?
- Irradic idle when warm...02 sensor?
- Finally installed my stripes.
- Fornt rotor removal 1st Gen 4runner
- Dash Swap questions....
- w56-A vs. w56-B transmission HELP
- idea on intake
- Econo aid sponsor...
- normal auto slugg or did i do something wrong
- 92 pickup 4x4 v6 Electric speedo or cable/
- My recovery #2 (slid off road!)
- steering stablizer shock - autozone
- 4Runner Pillar Lights?
- 88 pickup and lights
- need help lifting
- Any drawbacks to 33x9.5R15s?
- What should I do?
- Newb with questions (already searched)
- Quick question about lights..
- Oil Leaks! Help please
- CEL stays on & No Code - Any input?
- rear axle bearing...
- my new xrc8 winch/custom bumper...
- 22rte wont start
- Rocker Arms Hitting Valve Cover
- 90 yota
- winch?
- gears for factory 4.88 setup, will 4 cyl diff fit?
- 1st gear syncros....
- What do u think?
- buying a used automatic from a rolled 89 4runner
- ENGNBLDR Rocks!
- FREE SmittyBuilt Bumper...
- Cutting out/popping sound
- tire size...
- performance/mpg
- power steering
- VSV for PAIR system questions
- 92 4runner engine in a 88 p.u new here!!!
- Burnt Valve in #3...next step
- How rare?
- egr 22re
- Extending battery cables?
- Rebuild time for the 22-re
- take off grinding
- 89 4Runner ECM
- My flex is weak
- 87 runner
- 2nd Gen Winch Mount
- Need new tires help me pick
- 90 22re not running good, cannot figure it out
- selling my yota
- 93 Sas Leaf Spring Question??
- Electrical problem diagnosis
- Chevy horn in '86 Runner
- why is my 22re so loud?
- 95 3.0 4runner vacuum line not seen on any diagram
- 3vze: Shim stuck to bucket
- Writeup: removal of third and locker install
- Engine issues
- I hate being poor...
- interesting sound on startup
- reverse light problems
- Axles!!!!
- Overdrive light flashing and car not moving
- advise how to proper lift this 86 truck
- Braided Lines for Fuel Filter?
- Roof rack relocation
- 3.0 rebuild, acceleration problems...HELP!!!!
- mystery problem?
- Things to get for maintenance
- slider install?
- about the yt calender
- considering swapping in factory 4.88's - have a few ?s
- Fresh paint job
- crank pulley...
- Lights On 4runner
- spool or not to spool
- Sloppy shifter and shifting
- 22re Timing chain alignment?
- manual hub making noise
- Auto Trans Problem
- help 4wd drive wont work
- Tools for a Headgasket replacement
- Lift kits and tire size
- 79 toyota motorhome
- um.... what?
- crank i.d. question 22re
- My 4wd vs 2wd
- Sweeet find check it
- 94 Runner 3.0 auto tranny hard shift
- Remanned 3.0 Help
- They all come out when it gets frigid...
- Blocks and IFS...Kill me now.
- New '88 4runner!--problems :(
- Rn1 and VZN1 ?
- Burrnin Oil
- Early shifting / Poor throttle response
- Front Diff Issue
- Toyo vs Nissan
- ORS to close 12/18
- cold start
- Anybody have these aftermarket taillights?
- Craigslist 3rd gen
- 94 pick up v6
- gearing and tire size...
- rust question
- no instrument cluster lights, no runnng lights
- Here's a new one on a/c's...
- Ignition Lock Help!
- Rear Wiper Refill
- Resale value?
- squeak and pop in 2 gen Runner rear suspension
- ISR Mod Revisited
- I thought my motor finally ate it today...
- Vibration Wont Go Away/Cant Figure It Out
- Who makes the best rear disc conversion for 89-95 Pickups 4x4
- what causes the rear companion flange 30mm nut to loosen?
- Spare Tire Mounting Questions
- Where's your starter relay?
- finished head gasket, white smoke
- telescoping cv axle
- 92 4x4 V6 Parking break doesn't grab
- Dirty Pictures Wanted!
- Transmission Code 42
- lots of help needed
- Face bar
- Dual Exhaust on 94 4runner
- my toyota 4runner drives like a kangaroo
- gearing question!
- Not the average Master Cylinder question!
- Combining spring packs
- very frustrating fuel system problem
- long travel suspension
- Do I need dual transfer cases?
- 1992 4runner rear door windows and tailgate window won't work
- 3VZE timing belt pulley removal tool SST?
- 1-2" BL questions
- Part numbers for parking brake
