EngineRebuild
Old Dec 16, 2008 | 12:53 PM
95_4MuddinSr5's Avatar
EngineRebuild
Pulled the motor on sunday and got a lil carried away and just started tearing the block down. i forgot to mark the flywheels position to the crank, is this going to come back to bite me in the ass? I also pulled the distributor and realized i probably should'nt have after i already did, gonna mess me up too? how should i go about the heads and cams, should i put cyclinder 1 at TDC then tear it all down??? this is my first engine pull and overhaul and i got way to carried away. ill post pics in a bit.
Old Dec 16, 2008 | 12:58 PM
abecedarian's Avatar
3vze v6?
shouldn't affect anything at all. just put it back together correctly.
Old Dec 16, 2008 | 01:00 PM
Cyberman's Avatar
the flywheel shouldn't be too big of a deal. The distributor is no big deal. What engine is this?
Old Dec 16, 2008 | 01:03 PM
its the 3vze
Old Dec 16, 2008 | 01:06 PM
Tight Clearance
Is this oil sittin in my TB a bad sign?
On the stand
Old Dec 16, 2008 | 01:07 PM
I will post more pics, have my exhaust all off, valve covers, all brackets and accessories, and my timing cover off.
Old Dec 16, 2008 | 01:19 PM
So i just got done reading some other threads, and i guess im just going to mark from here on out and forget about what i already did. ill keep posting pics of the rebuild, and probably keep asking more questions.
Old Jan 15, 2009 | 01:44 PM
So i got my block down to nothing and the heads along with the block to the machine shop. The number 2 rod looked real dark and might have a bad bearing, but it wasnt loose at all on the crank. All the cyclinders look good, no major looking problems. Besides being extremely dirty, looks good, and should be back it hopefully late Febuary.
