coolant temp sensor goes to ECU or gauge??
Old Dec 16, 2008 | 07:04 AM
89pickupsr5's Avatar
Question coolant temp sensor goes to ECU or gauge??
I have an 89 pickup with a v6
which one goes to the gauge the cold start injector time switch or the coolant temp. sensor
thanks drew
Old Dec 16, 2008 | 07:15 AM
atistang's Avatar
should be a coolant temp sender, as in sending unit
a sensor tells the ecu whats going on, a sender sends a reading to a gauge
Old Dec 16, 2008 | 10:39 AM
thook's Avatar
Niether of those sensors........what atistag said. The sending is on the same cluster at the back of the lower intake manifold near the firewall, though. That is if you don't know where they are.
Search this forum for "sensor id" or "identify this sensor" or "sensor identification". You can use Mt. Goat or thook.....off the top of my head....as "post by user" input to add. In one or two threads floating around here, this topic has been clarified to include pics on part locations and functions. This should help. If you have trouble finding it, post back and I'll find the info for sure.
the1998sr5
15
Jul 14, 2020 08:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
