Installing engine tomorrow, need help
Old Dec 13, 2008 | 05:52 PM
Rocketwrencher's Avatar
Downey doesnt have enough orders to warrant an order with their supplier so I am going to install the motor with the stock manifolds and switch them over later. I am going to install the motor tomorrow. The problem is, I cant put the truck in neutral. It is an auto. The battery is good, but I cant shift it to neutral. I have been able to in the past as long as the battery was good. Short of dropping the driveshaft, I dont know what else I can do. I need to be able to move the truck because I am not using a mobile cherry picker. Anybody got any ideas?
Old Dec 13, 2008 | 06:07 PM
thook's Avatar
Um....drop the driveshaft?...... <<<ducks as wrench is thrown<<<
Old Dec 13, 2008 | 06:12 PM
Thanks thook. But why was I able to put the truck in neutral before. <<laughing as I throw the wrench>>
Old Dec 13, 2008 | 06:27 PM
TacoNut's Avatar
In my 2004 the key has to be in the on position and the brake drepressed to shift from park. It's a safety thing. However there is a small cover by the P onthe shifter, left side. Pop the cover off and depress the small button. You should be able to shift it to neutral. It is a shifter lock bypass for towing etc without the key.
Old Dec 13, 2008 | 06:32 PM
Thanks Orem, I will check that out in the morning. If not, I guess I will have to drop the drive shaft..
Old Dec 13, 2008 | 07:13 PM
thook's Avatar
Do what he suggested. (Good posting!) As you long as you have power to the system, you should be able to. It's the same in my wife's '92 auto. I do believe it's the same for any automatic ECT unit.
Old Dec 13, 2008 | 07:15 PM
bigt's Avatar
my hilux has a red button on the auto tranny if i press this i can shift whenever! has some japan writing beside it like everything!
Old Dec 13, 2008 | 07:16 PM
abecedarian's Avatar
umm... what? you used to be able to but now you can't?
huh?
pull the shifter and move the linkage manually.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
coryc85
Sep 9, 2015 06:24 AM
jon.r
Jul 11, 2015 03:34 PM
bryan34w
Jul 6, 2015 05:53 PM
