Rocker Arms Hitting Valve Cover
Old Dec 12, 2008 | 10:17 AM
Whiplash Willy's Avatar
The rocker arms on my 22re are hitting the valve cover. In order to stop this from happening, I loosen the valve cover nuts. The problem is, If I tighten the nuts tight enough to hold the valve cover on, and not have air escape from the grommets between the valve cover and the nuts, the rocker arms will hit the valve cover. If I loosen the nuts to where they dont hit, the nuts are easily removed by hand and air will leak through the grommets.
Is there a way to get them to stop hitting the valve cover besides loosening the nuts? How bad is it on the engine to have the rockers hit the valve cover?
Old Dec 12, 2008 | 10:40 AM
Ed H.'s Avatar
bad, negative ghostrider
check your vc gasket it might have folded over or fell out of that groove causing it not to tighten down properly, and there are two different valve covers for 22r and 22re's i dont know if there is a difference in clearence though so if you have the right one for your truck then you are good should be the more squared off one.
Old Dec 12, 2008 | 10:41 AM
sincal's Avatar
sounds like your grommets are shot. When you tighten the nuts its just squeezing down too far. I would recommend getting new grommets.
Old Dec 12, 2008 | 12:17 PM
Junkers88's Avatar
I'd suggest getting a new gasket set to include the 4 rubber grommets and those 2 half mooned ones on the front and rear of the head. Mine were pretty mooshed compared to new ones when I replaced them.
Old Dec 13, 2008 | 07:05 AM
thook's Avatar
X2......new set. Hopefully you didn't warp the valve cover.???
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
razorman8669
Jul 12, 2015 12:13 PM
