88 toyota timing problem
Old Dec 17, 2008 | 05:24 AM
lightemup's Avatar
i have a 88 toyota pickup that i just did a head gasket on. after days of with it i finally got it running, but it lacks a lot of power and im pretty sure it ignition timing. ive redone the timing about 5 times and still lacks power but each time i do it, it gets better. ive been using a chilton manuel and still cant figure it out if some could please help me out thanks
Old Dec 17, 2008 | 05:37 PM
abecedarian's Avatar
you're shorting the E1 and TE1 terminals in the diagnostic connector behind the battery, correct? and when you do that, the idle speed changes, correct?
Old Dec 18, 2008 | 12:49 AM
lightemup's Avatar
i figured everthing with the timing today now i got another problem im getting a c.e.l code 25 and thats because the o2 sensor is not plugged in but i cant find a connector any were that would fit the o2 sensor the truck ran great before i swapped motors with an 86 but i put the 88 wiring harness and efi from the 88 motor, and that motor never had a o2 sensor and it ran great lots of power. i want to know how that motor could have ran with out a o2 sensor and this motor is running like because it has one, and yes the 88 motor should have one but it doesnt. so any help on the would be great thanks.
Old Dec 18, 2008 | 09:54 AM
the o2 on an 88 should be under the cab, in front of the catalytic converter.
did you look there?
Old Dec 18, 2008 | 01:48 PM
lightemup's Avatar
found it haha toyota likes to hide things i see well thanks for all the help now im getting code 25 should i swap and o2 sensors with the 86 and see if it helps or buy a new, im flat broke i spent all my money trying to get this thing running again so let me know what you guys think thanks.
gillesdetrail
Nov 19, 2019 12:56 PM
the1998sr5
Oct 19, 2016 12:48 PM
vasinvictor
Jan 20, 2016 12:39 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Old Red 94
Jun 16, 2015 08:32 PM
