power band on a 22re?
Old Dec 15, 2008 | 02:28 PM
Junkers88's Avatar
I did some searching and read lots of differing "ideas" on where the powerband is on a 22re.
Where is it? 2200-2500? 2700-2900?? 3000-3500???
Mine tends to pick up at 3100 and really ramp up until 3500 but I've done the supra afm mod and am unsure if it's the new afm or the motor. I'd like to try driving in the powerband to maximize economy but am unsure where it is.
Thanks folks.
Old Dec 15, 2008 | 02:42 PM
abecedarian's Avatar
this help?
(it's a chassis dyno read-out, not an engine dyno)
Old Dec 15, 2008 | 02:57 PM
Trustyrusty's Avatar
God thats so pathetic.. Hahaha!
Old Dec 15, 2008 | 03:04 PM
here's a little more about that dyno run... as you read, you'll see it's a mildly modified engine. I would expect between 5-10% less from stock and the powerbands moved down about 500 rpms or so.
from: http://www.pirate4x4.com/forum/archi.../t-505341.html
This was when this motor was fresh. Only 1K miles on it if that.
'87 Block 22RE block
engnbldr.com "high out put" new cast head w/ over sized stainless valves
DOA 270 cam
.040" over engnbldr.com cast pistons
rew rods, machined '87 crank
stock flywheel
DOA Thorley header to 2.25" exhaust incl. cat and Flow Master 50 muffler
cleaned stock injectors
new TPS
intake was spotless inside
stock ignition @ stock timing, new plugs, cap, wires and rotor
If I remember right it was about 50*
ran through the stock W56 trans a single case
stock 4.10s with heavy ass 245/75/16 MTRs on T100 steel wheels.
Old Dec 15, 2008 | 05:36 PM
Wow the more I think about it, thats frickin terrible, and it was modified? HAHAHA! These things are GUTLESS! Short gearing makes 'em haul though! Sorta..
Old Dec 15, 2008 | 06:01 PM
just a 22re's Avatar
wait you mean the 22re has a power band? since when??is that what happens at 6,300 rpms? i though they just make the wheels turn like a electric car does lol
Old Dec 15, 2008 | 06:52 PM
texcat101's Avatar
This is the kind of irresponsible post that just might lead some one down a long steep path of self destructive behavior.
22re's do not, I repeat do not have a power band.
Shame on you all.
Old Dec 15, 2008 | 07:29 PM
874runnersr5's Avatar
lol, powerbands are 22re's dont mix.
let alone, horsepower and 22re's lol.
Old Dec 16, 2008 | 03:34 AM
all cynicism aside... shame on you all.
and how many of you have a 22re in your ride?
Old Dec 16, 2008 | 05:23 AM
annoyingrob's Avatar
Shame on you all.
Exactly. This is how I always measured the performance of my RE: <3500rpm, no power. >3500rpm, less than no power.
The shifter is actually the "noise adjustment lever". All it does is change the amount of noise the 22R makes
Old Dec 16, 2008 | 05:32 AM
saitotiktmdog's Avatar
Mine really picks up after 2000 and really pulls at 3000. But then again I have a little help with forced induction. But I have heard ( I think from Ted at engine builder) that cruising rpm range is between 2500 and 3000 rpms for the 22r.
Old Dec 16, 2008 | 09:16 AM
me!
Old Dec 16, 2008 | 11:36 AM
chrisbnaz's Avatar
Ew.
That dyno really did make me a little sick to my stomach. Thats about what I expected though. Everytime I go from driving the yota to driving the Camaro I feel like I just strapped into the space shuttle.
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
mlavery85
Jul 12, 2015 10:33 AM
