Fuel pump issue
Old Dec 14, 2008 | 07:00 AM
gametom's Avatar
Fuel pump issue
Hello All my fuel pump is not turning on and before i take the tank off i wanted to test if it's just not getting power, so under the passenger side rear seat theres a access panel that has a wiring connector there is that the fuel pump connector? i can't find anything about it in the fsm i see that the pump is applied battery + and has a constant ground. how can i test this without dropping the tank.
Thank you
My truck is being a pita lately!!
Old Dec 14, 2008 | 07:07 AM
the_ocho's Avatar
hey try this
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Dec 14, 2008 | 12:37 PM
scuba's Avatar
Courtesy of Roger
Thats what your going to look for in your engine bay...
if you can here the fuel pump whining with that then you have another problem then the fuel pump going out...
Old Dec 15, 2008 | 10:56 AM
somis13's Avatar
mine wouldn't start at all and while testing with a test light for power at the pump while cranking the engine over, after 2 seconds the light lit up, pump turned on and the engine started. all I could come up with is maybe I reset the relay while probing the wire. cuz now it starts and runs fine.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
