Best headlights
Old Dec 13, 2008 | 10:34 PM
Gokumono's Avatar
Best headlights
What do you guys think are the best headlights to get?
Not talking about HID either. Just ones that go in without any mods.
I know there is another thread somewhere with something like this, but cant find it.
Old Dec 13, 2008 | 10:36 PM
Elton's Avatar
if its the 4runner in your sig theres not much you can do ... you could try some silverstar ultra's and upgrade the wiring harness
Old Dec 13, 2008 | 10:39 PM
Gokumono's Avatar
Ya. It is. I saw some bad reviews on silverstar and saw some suggestions of something else, but cant remember what.
Old Dec 13, 2008 | 11:01 PM
Robert m's Avatar
Osram night breakers. they are freaking awesome
Old Dec 14, 2008 | 04:53 AM
flashkl's Avatar
Osram silverstars are good too, if you can get a hold of some. Sylvania silverstars have the blue coating on the bulb so they aren't as effective. Plus they burn out really fast, supposedly.
Old Dec 14, 2008 | 06:12 AM
MMA_Alex's Avatar
??? you do realize the company is called osram sylvania right?
I've had silverstars, and theyre brighter than regular bulbs, but burn out extremely quickly.
not sure on the 95,but If it has the 200mm sealed beam bulbs your best bet is to get new headlight housings which can have bulbs plugged into em. yes, i realize you said no mods, but its the same amount of work as changing a sealed beam.
Old Dec 14, 2008 | 06:21 AM
nv4runner's Avatar
My 92 4runner has composite head lights, so hopefully the 95 does too. I've had luck with the silverstars, but I also got rid of two of the locating tabs inside the lens and swapped the high beam and ground wires so I can run 9007 bulbs instead of the 9004's. I believe it to be a better light pattern, but it also has to be aimed fairly low.
Old Dec 14, 2008 | 06:23 AM
akaphilly's Avatar
see advertisement on left of main page https://www.yotatech.com/ i got them a few weeks ago and couldnt be more happy. wish i got them 4 years ago
Old Dec 14, 2008 | 07:00 AM
jason724's Avatar
I'm happy with my silverstar ultra's. They were ~$42 at my local Pep Boys, but they're so much brighter than the lame stock replacements. You can also give one of these a try: http://autolumination.com/headlights.htm
Old Dec 14, 2008 | 07:08 AM
SurlyJohn's Avatar
I have the 9004 Silverstar Ultras in my 94 4runner, had them like 2 years now. I used latex gloves to install them, you should use gloves from the second you open the package to when you are done installing them.
Any oil from your skin will cause a hot spot and burn out your bulbs prematurely. These do throw a much better pattern than the stock 9004's they replaced which were very yellow and dimmer overall.
I'm very happy with the Silverstar Ultras, got them on Amazon.com for $30 on sale.
Old Dec 14, 2008 | 07:09 AM
the_ocho's Avatar
Im running silverstar ultra's and they are amazing.
Old Dec 14, 2008 | 07:57 AM
RiCh_90-yota's Avatar
Try some PIAA's there pretty bright!
Old Dec 14, 2008 | 08:25 AM
Gokumono's Avatar
I dont see the ad about headlights.
Yes it is for the 95 4Runner in my sig. It has composite. The bulb comes out, not the lens.
So far im seeing Sylvannia, Osram Night Breakers (Sylvannia?), and PIAA
What PIAA model would I need? Any idea?
Or a link to a site that would say.
Any other ideas?
Thanks for all the posts.
Old Dec 14, 2008 | 10:12 AM
Tubbyfatty's Avatar
Ive got some 100/80w "off road only" bulbs that are in my truck right now. They are way better then the Sylvannia's ive used in the past.
I got em at knechts for $12 a piece. When looking for bulbs i usually looks for the highest wattage ones.
I posted a thread on here a while back about em. I forgot what its called, i think"new headlights" or something like that.
Old Dec 14, 2008 | 10:19 AM
Tubbyfatty's Avatar
Heres a few pics of mine, i just found the thread
https://www.yotatech.com/forums/f116...-bulbs-159923/
Old Dec 14, 2008 | 10:44 AM
JJ'89's Avatar
This guy is in the lighting business...
http://www.slantsix.org/forum/viewtopic.php?t=32393
Old Dec 14, 2008 | 11:47 AM
1989toy4wd's Avatar
I have had my silvanias in for 3 years and they are still working good!!! They are the whole sealed beam though!!! They put out better light then my chevy...well they did before the SAS
Old Dec 14, 2008 | 11:56 AM
flashkl's Avatar
Yes, the company is osram sylvania, but they produce two different silverstar bulbs, one under the sylvania brand name and one under osram. The osram one is the better of the two.
Old Dec 14, 2008 | 12:47 PM
Gokumono's Avatar
Where can you get the osram?
Old Dec 14, 2008 | 03:35 PM
Robert m's Avatar
ebay is where i got mine
