22rte wont start
Old Dec 12, 2008 | 10:32 AM
86turbotoy's Avatar
22rte wont start
any help im geting fuel to the cold start injecter and i have spark cant figure out what it can be timing has been checked. The engine was just rebuilt anyone know what it can be. there is a white double plug under the intake by the fire wall one plug goes to the transmission where does the other one go.
Old Dec 12, 2008 | 11:07 AM
annoyingrob's Avatar
Is the distributor 180* out?
Old Dec 12, 2008 | 11:13 AM
TOYOTA 1's Avatar
^x2.. does it even try to run?
there should be 3 plugs..
1 goes to the tranny for reverse lights. one goes to the o2 sensor, and one goes to you transfer case for the 4x4 light.
Old Dec 12, 2008 | 11:16 AM
tc's Avatar
tc
Only 3 things to check - fuel, spark, air(compression) and you've checked 1.5 of them.
x3 for distributor 180* out.
Old Dec 12, 2008 | 11:40 AM
86turbotoy's Avatar
it wont even attept to fire i have checked the timming a couple times. I cant put my finger on what is wrong its driving me crazy.
Old Dec 12, 2008 | 12:16 PM
86turbotoy's Avatar
anyone got any other ideas
Old Dec 12, 2008 | 03:33 PM
regularjoe's Avatar
would you have spark even if it was 180 out? I dont know alot about the subject.
Old Dec 13, 2008 | 09:32 AM
86turbotoy's Avatar
I belive it would have spark if it was 180 out. i have spark but it is very faint i think it might be the ignighter anyone know how to check if its good.
Old Dec 13, 2008 | 09:45 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
If its isnt even turning over check
1. starter is actually in the hole, i had mine fall out on the way home from work last week, and wire brush the contacts and terminal
2. check fuses takes about 4 minutes to check all of them
3. make sure all of your grounds are hooked up (valve cover, chasis to engine coming of starter wire)
If it is rotating but not catching check
1. if it cranks all slow or backfires out of the air box, turn your dist around
2. pull the 19mm bolt going to the fuel rail, you will need a new crush washer, and see if you have a steady stream of fuel with the key turned to acc. dont try to start but see if you have constant flow (fill a beer can in a minute or so), if this is weak it could be sending unit, pump or pressure reg.
3. make sure all of your plug wires are on the correct spot, plug wire 1 on the number 1 location on the cap.
4. Spray some brake cleaner in the throttle body while attempting to start, and see what that does.
Old Dec 13, 2008 | 10:18 AM
86turbotoy's Avatar
the moter turns over fine all my grounds are hooked up im getting fuel to my cold start injecter. its just like theres not alot of spark
Old Dec 13, 2008 | 11:13 AM
TOYOTA 1's Avatar
weird.. is there somebody you could swap out igniter/coils with?
Old Dec 13, 2008 | 11:35 AM
86turbotoy's Avatar
ya i have wait till monday my friend has more toyota parts than he know what to do with 7 bays full.
Old Dec 13, 2008 | 04:46 PM
mistreatedtoys's Avatar
Have you pulled the plugs to veriify fuel is being injected? You will have pressure but if the injectors are not firing all is for nothing. This happened to me after a head gasket change. The wires got pulled loose from the plug. The connector was tight but no contact was being made. Check the wires and connector coming of the silver finned box on the passenger side firewall. It will be an insulated 2 wire white with yellow connectors.
Old Dec 13, 2008 | 09:08 PM
New cap, rotor, plugs, and wires?
Old Dec 13, 2008 | 09:30 PM
abecedarian's Avatar
I'm wondering... how do you check the timing if the engine won't start?
Old Dec 13, 2008 | 09:32 PM
20r/22r/22re/22rte
crank at 0
cam at 0: intake and exhaust valves loose on #1 cylinder
distributor removed, rotor at 12 oclock, insert, should rotate CCW to about 10 oclock.
Old Dec 13, 2008 | 09:33 PM
874runnersr5's Avatar
x2.....
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
