Cracked Radiator this morning, freezing cold
Old Dec 16, 2008 | 06:46 AM
g_mau18's Avatar
I was driving to work this morning and the heat gauge rose dramatically, I pulled over and steam was erupting out of this tiny crack on the upper left hand side of the radiator. anyone know what caused this?.....my guess is that its stock since 1988.
Old Dec 16, 2008 | 07:01 AM
atistang's Avatar
probably just old and brittle.
or you had to much water mixed in and it froze up over night
just make sure you mix your antifreeze right when you put a new radiator in
Old Dec 16, 2008 | 07:02 AM
mt_goat's Avatar
My stock 93 radiator only made it to about 2002 before it developed tiny pin holes along the top from corrosion.
Old Dec 16, 2008 | 08:15 AM
Matt16's Avatar
I don't know where you're from, but here in the NW, its been extremely cold, maybe your antifreeze isn't the right mix.
Old Dec 16, 2008 | 08:39 AM
g_mau18's Avatar
yeah tacoma, wa. its been freezing
g_mau18's Avatar
oh well, 130 bucks for a brand new radiator, not bad
Old Dec 16, 2008 | 08:46 AM
jsn_stockard's Avatar
I bought one from Oreilly's and when it came in I was shocked, It was a 3 core! Paid $125.
atistang's Avatar
you might check out rockauto.com
sometimes they have very good prices
Old Dec 16, 2008 | 09:21 AM
freddy's Avatar
Well..is 20 years old u cant be mad at it for braking.
Old Dec 16, 2008 | 09:24 AM
g_mau18's Avatar
I did remove and reinstall the radiator when i did my engine swap, but that was a while ago, how long will it take to take the old radiator out and install the new one, work is going to give me 2 hours to do it.
Old Dec 16, 2008 | 09:38 AM
mt_goat's Avatar
I think the book rate allows about 1.2 hours
Old Dec 16, 2008 | 09:46 AM
swaycleveland's Avatar
25 mins for the " in and out" probly another 15 to burb it
Old Dec 16, 2008 | 02:30 PM
desertcox05's Avatar
my stock 89 rad only made it till 2008. pos. easy swap out in 2 hours if you have any skills
Old Dec 16, 2008 | 02:33 PM
sa51's Avatar
easy swap in a max of 2 hours
barring catastrophic event
Old Dec 16, 2008 | 02:41 PM
Junkers88's Avatar
Make sure your anti freeze mix is right, I run about 90/10 anti freeze/water but that's what I've always done. Check the manual to be sure.
My factory 86 rad only made it until 08 so these things do fail after a while. It took me about 30 minutes to drain/pull/replace/fill/burp the new one.
Old Dec 16, 2008 | 02:46 PM
thook's Avatar
Manual says 50/50. 90/10 is a bit rich on the coolant, though. IIRC, 60/40 is the most one should even need.
thook's Avatar
......that is, in most situations.
Old Dec 16, 2008 | 08:01 PM
Jay351's Avatar
There is a writeup in the tech section on how to change your rad. Pretty easy job..
I R&R the rad on my girls 22re runner, that was easier then on my truck.
Partly because my rad is bigger and my truck is about 8" higher...
I run a 50/50mix of Toyota coolant and distilled water
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
horunner1x
Jul 10, 2015 06:33 AM
