4wd actin weird
Old Dec 7, 2008 | 05:52 AM
yoder519's Avatar
4wd actin weird
it was snowin in my area last night, and my driveway was covered with ice. i tried twice to get up it in 2wd and couldnt. so i went and locked my hubs in. when i put it in 4high, the front end of my truck bounced bad. it felt like i had square tires if you can imagine that. the fourwheel drive worked, but it bouced bad. adn it wasnt bc i was on paavent either bc ive drove it in 4wheel drive on the road before and it wasnt near this bad. i checked my cv axels and they look fine. im blank. so help me out fellers!!!
Old Dec 7, 2008 | 08:19 AM
tc's Avatar
tc
How does it drive with the hubs locked and in 2WD?
Old Dec 7, 2008 | 09:05 AM
yoder519's Avatar
it does the same thing. i just drove it like that. my CVs are only about 2 months old. could it be caused by a steep angle on the CVs? cuz mine are really steep. you cant hardly see the cvs in the pics but you can tell there ssteep by the a arms i guess there called
[IMG][/IMG]
Old Dec 7, 2008 | 09:11 AM
tc's Avatar
tc
Well, that's good - it means it's probably not in the tcase.
Your sig says you have a 3" AAL and BJ spacers - so did you crank the tbars to make it level?
My next suggestion would be to jack up the front and spin the wheels by hand (with the hubs locked tcase in 2WD) and see what you can see/feel.
Old Dec 7, 2008 | 09:13 AM
yoder519's Avatar
yea my tbars are cranked to level it up. ok ill try that thankye very much
Old Dec 7, 2008 | 09:30 AM
yoder519's Avatar
come to think of it thats the first time ive had my hubs locked in since the new cvs. my old ones did fine after my lift and everything. so maybe the guy that put em in for me did somethin wrong??
Old Dec 7, 2008 | 06:14 PM
yoder519's Avatar
im pretty sure now that the reason it bounced so bad is bc of the steep angle. im gonna let down my tbars to stock height and put a 2inch leaf or block in the back
Old Dec 7, 2008 | 06:20 PM
abecedarian's Avatar
other things to check:
... are your front prop shaft u-joints timed properly? (and I'm not sure this is your problem 'cause I can't imagine someone doing it to install BJ spacers, but you never know )
... are your front and rear tires the same size?
Old Dec 7, 2008 | 06:26 PM
yoder519's Avatar
yea my all 4 are 31s all the same brand except the back right lol. but afte rmy lift i noticed that my front tires dont stick out AT ALL and my back tires do just like they did b4 the lift. no tsure wha tthe front prop u joints are... ill have to do a little seachin and get back to you on that one. hay.. atleast im honest
Old Dec 7, 2008 | 06:30 PM
the front prop (propeller) shaft is the front drive shaft from the transfer case down to the front differential. my bad for not explaining that.
Old Dec 7, 2008 | 06:38 PM
Matt16's Avatar
Here's why its important they are "timed" or "in phase"
http://www.4crawler.com/4x4/CheapTri...ies/ujoint.avi
See how the driveshaft accelerates and decelerates while the speed of what would be the diff pinion flange and the T-case output flange stay constant? If the two u-joints are out of phase, then there will be some vibration.
From 4Crawler's page http://www.4crawler.com/4x4/CheapTri...line-101.shtml
That said, unless you had a tall bracket lift (and big driveline angles), I wouldn't think this would be all that noticeable. I would put my money on it being that your CVs are at such a steep angle that they are binding. Only way to fix this is by lowering the T bar crank.
Old Dec 8, 2008 | 05:37 PM
algranger's Avatar
where did you get yer 3" aal?
Old Dec 8, 2008 | 06:22 PM
yoder519's Avatar
you always got good info lol. bu tseriously... you do. i think its bc of the steep angle also. im buyin a 2inch aal and lettin my tbars back down. hopefully next week. plus im gettin 35s with 3/4 tread fro $200 bucks !
Old Dec 8, 2008 | 06:30 PM
Beaniam's Avatar
truck off, in 2wd get under it and lock one front hub at a time and turn the front driveshaft by hand. see if either of the cv's are binding at ride height. that's about the same angle mine are at and only one of them slightly starts to bind a full droop so I'd be surprised if that's your issue. at least by getting under it and turning the driveshaft by hand you'll have a much better idea of where the issue is coming from
Old Dec 9, 2008 | 10:04 AM
yoder519's Avatar
alright ill give that a try when i get the chance. how rough does your truck ride? i think its where my cvs are at such a bind because as steep as they are, it looks like there not even hardly long enough
Old Dec 9, 2008 | 10:11 AM
Beaniam's Avatar
well I can't really say how mine ride, I only lock in the front hubs when I need 4 wheel and that's only ever in low range under 15mph. I have no weird vibrations or binding though. I extended my droop bumpstops and inch to prevent binding.
Old Dec 9, 2008 | 10:26 AM
yoder519's Avatar
no i mean just normal road drivin
Old Dec 9, 2008 | 10:53 AM
Beaniam's Avatar
well in my normal road driving the hubs are unlocked so the cv's and front driveshaft aren't spinning. however if I have to take a quick trip on pavement or a 1/4 mile or so with the front hubs locked I still don't have any major vibrations. I can feel them spinning though.
Old Dec 9, 2008 | 02:51 PM
Matt16's Avatar
How much lift dialed in? My hubs are pretty much locked from Nov- Mar without much unlocking. NEver noticed a difference in ride, noise, mpg etc...
Old Dec 9, 2008 | 10:45 PM
Beaniam's Avatar
1.5" BJ spacers and about 1" Tbar crank
kawazx636
Oct 6, 2021 03:03 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
