crank pulley...
Old Dec 10, 2008 | 11:23 AM
elnino's Avatar
crank pulley...
so how do i remove it? do i need a puller?...or is there a trick for that?
Old Dec 10, 2008 | 11:43 AM
allnmstkn313's Avatar
Use a gear/pulley puller. Can rent/buy them at most auto places.
Old Dec 10, 2008 | 11:46 AM
DeathCougar's Avatar
Crank pulley? Or harmonic balancer.
The crank pulley drivers the timing belt, the balancer drives the accessories.
Old Dec 10, 2008 | 11:48 AM
ozziesironmanoffroad's Avatar
if its the one im thinking of, on the harmonic balancer, just take an impact to it.
91Toyota's Avatar
No puller needed. Should come right off. Same with harmonic balancer.
Old Dec 10, 2008 | 11:51 AM
elnino's Avatar
so they should just be able come out once i remove the bolt?....
The problem, oft times, is those pulleys rust or corrode on there. I have had them both ways when working on vehicles. One Prizm (Corolla) I worked on had the crank pulley (drive gear) rusted on so bad, i had to beat it with a large hammer and a pry bar. That of course destroyed it, and I had to buy a new one from toyota for $40.
Old Dec 10, 2008 | 11:59 AM
87LVRunner's Avatar
Hijack but didn't want to start a new thread. Is there a way to remove the timing cover, waterpump housing without dropping the oil pan? Looking at it, appears I have to drop the pan. Any tricks out there?!
Old Dec 10, 2008 | 12:38 PM
Take out the 4 or 6 bolts holding the pan to the timing cover, and then unbolt the timing cover.
Old Dec 10, 2008 | 01:18 PM
874runnersr5's Avatar
just drop the oil pan, if your drivers side guide was is missing.. trust me its worth it.
i droped mine by unbolting 3 bolts for the front diff.. after that it'll give you enough clearance to work. I pulled a handfull of plastic out of my pan.
Old Dec 10, 2008 | 01:38 PM
jsn_stockard's Avatar
I would take the pan all the way out to get the plastic chunks off of the pickup screen, trust me, they are there. I have done 8 of them. As for the pully, if it wont come off pop it a few times with a rubber or dead blow hammer and it might pop loose
Old Dec 10, 2008 | 01:40 PM
91Toyota's Avatar
Yep...I have a harmonic balancer puller for an old 460 block I had. I was going to put it in my ford ranger but decided I could never afford it. lol
Old Dec 10, 2008 | 01:43 PM
87LVRunner's Avatar
Just did the pan not too long ago. Chain, guides, and HG were done at 180K. I'm at 242K now with the coolant leak. Yeah, the shop that did teh job originally is in another state. (previous owner) So, it's all off again and I am going to replace it all including the head, cam, valves. Big fun!
Old Dec 10, 2008 | 01:55 PM
i though it was hard trying to put hte pan back in with that oil picking line in there.
Old Dec 10, 2008 | 02:10 PM
Not if you drop the front diff out of the way, gives you plenty of drop room
Old Dec 10, 2008 | 02:12 PM
oh i did, i found it just trick to apply rtv to the pan when it was under there
i guess i couldve applied it while it was out
JonG85
Jan 18, 2023 04:31 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
gentry
Sep 28, 2015 06:16 AM
