Chevy horn in '86 Runner
Old Dec 11, 2008 | 06:48 AM
imike420's Avatar
I found a horn out of a '74 Chevy 1500 and it sounds much better than the stock 'Yota one. I just cant figure out the wiring. The 4Runner horn has two wires and the chevy ony has onee on the horn. I tried hooking up the positive wire tothe horn and the negative to ground and the horn stayed on constant. If I just hook up the positive wire to the horn and leave the negative off nothing happens. I tried looking around on here and a couple of other forums but I couldn't find anything. (Probally becaust this is something very easy and I just can't figure it out.)
Old Dec 11, 2008 | 06:51 AM
littlecommando's Avatar
it is because chevy switches positive and uses the mettle its mounted on for ground, and toyota doesnt
welcome to yotatech!
Old Dec 11, 2008 | 07:28 AM
imike420's Avatar
Thanks!! So, it is probally more work than it is worth trying to put that one in? Do you know of any other manufacturer that makes a decent sounding horn that I could wire in here a little easier? (I'm a little broke and was hoping to find something in the local junkyard.)
Old Dec 11, 2008 | 07:54 AM
AP4CHE's Avatar
This one.
Old Dec 11, 2008 | 08:07 AM
ozziesironmanoffroad's Avatar
doesnt sound like the horn in dukes of hazzard...
Windsor's Avatar
You can rig a relay for the electrical conversion, if you want to use domestic dime-a-dozen horns.
Bosch relays and sockets are relatively cheap.
Relay for $3.19
socket for $1.75
(Mazda does the same "ground to make circuit live" method in their RX-7s)
Old Dec 11, 2008 | 08:08 AM
just mount it up on the metal in the engine compartment . sand the paint to bare metal and mount it there. theres your ground. that should do it.
Old Dec 15, 2008 | 09:39 AM
imike420's Avatar
Thanks, I will try that as soon as the weather clears up.
Old Dec 15, 2008 | 10:27 AM
Matt16's Avatar
To reiterate, as I undestand it, the Toyota horn is permanently attached to the (+), to complete the circuit, the (-) is completed.
MTLroadierunner
Jul 15, 2015 12:58 PM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
