rear axle bearing...
Old Dec 12, 2008 | 10:54 AM
elnino's Avatar
well i searched and it said i had to remove the third member,axleshaft..and well....change the bearing...is just that? or is it there more to that?
Old Dec 12, 2008 | 11:04 AM
tc's Avatar
tc
What rig?
No, you don't have to remove the third if you're talking about the outer bearnig on the axle.
You will need a BEEFY press with a long throat to press the old bearing off and the new bearing on.
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
Old Dec 12, 2008 | 11:34 AM
elnino's Avatar
94 pick up ...yeah the outer..
Old Dec 12, 2008 | 11:53 AM
tommy316's Avatar
I just replaced this a couple weeks back. Couldnt figure out a way to get the old bearing off so just broke out the torch. Used a 20ton press to get the new one on, just make sure you do it in the right order. I think we ended up using a large socket to help press the bearing in. It can be a PITA. Remember to replace the oil seal while you are in there!
Old Dec 12, 2008 | 07:34 PM
elnino's Avatar
do i have to remove the third member?
Old Dec 12, 2008 | 07:55 PM
tommy316's Avatar
nope, you should drain the oil first though so none spills out.
Old Dec 12, 2008 | 09:13 PM
desertcamper67's Avatar
Or just put your oil drain pan under the backing plate so when you separate the axle from the housing it will drain neatly.
Old Dec 13, 2008 | 01:16 PM
85toy's Avatar
i suggest taking the axle shaft to a shop, should cost about 40 bucks. and do not use a torch on it.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
toyoda8488
Jul 5, 2015 10:18 PM
