- 22r? ever come with dual timing chain?
- Engine? tranny? 1988 Pickup
- Bucket seat install?
- Broken Bucket Seat?
- Chou Seki alloys
- 4runner hardtop price?
- oil cooler lines
- Front End noise, Help me identify
- What are the two plastic boxes on the side of the airbox?...
- Rear Seat Fold-ability Help?
- 22r died twice while driving, now won't start. Cause?
- TPS Adjustment: Resistence Reading Question
- Need help with EZ Locker!!!!!
- Weird electrical problem all of a sudden! (Long!)
- Questions on manual hub swap?
- What is this and what does it do?
- How to determine if steering recall has been done?
- front end off or brakes?
- 87 4Runner Engine Problems
- Possibly buying a 4-runner
- too early for timing chain?
- 60,000 mile maintenance?
- Urinating throttle body
- Gears for an '89 1ton?
- My new addition
- Love this site
- 22RE weight?
- Replace torison bars w/ Coilovers
- no more 4wd?
- Knock Sensor Trouble Code Wire Shielded Huh?
- RN, VZN, etc. nomenclature
- Stumbling/Hesitation during acceleration
- Seat Bracket Question
- what happens with disconnected TPS
- 3 inch lift questions
- trans shift problems
- Transmission Giving out in 89 v6 3.0 HELP!!
- 91 2wd lift
- Keep chrome steel wheels or run my sr5 alloys?
- Max tire size on Enkei 15" runner wheels
- first time it revs high on startup- granted its 9 deg. What gives?
- Hey all, thinking of buying this 4runner
- Something in the oil, I think..
- How can I test my injector connectors
- Should I rebuild or get a Jasper? And other questions
- Missfire at startup?
- Really low idle
- motor compatability
- Front Diff Question
- What is this top end noise?
- factory alloy wheel swap
- Fuel side electrical problem
- Later wheels on a 90 4runner
- Back window question
- Trying to comprehend IFS lift
- Rear Disc Brake Conversion and other mods
- 89 pickup Wiring help.
- Twitching AMmeter
- 22r 2wd twice as fast as 22r 4wd?
- why are 3vze engines so bad about blowing head gaskets?
- really bad gas mileage
- BVSV (Bimetallic Vacuum Switching Valve)
- need to replace timing cover - friend says to just do a head gasket
- 3.0 Valve adjustment
- 2nd gen 4runner w/22re?How many out there?
- another swap question
- Engine/Transmission Separation Problem
- anyone know what part this is on the 3vze?
- Junkyard swap?
- my 4Runner sounds like a jeep
- Hub Explosion
- Changing Valve Cover Gaskets
- P/S left....Manual to the right
- Complete drivetrain fluid change, please verify
- Testing window switch?
- what should i do?
- more rear window problems.
- door replacement
- Does my engine diagnostic stuff even work
- Hello with Pics of the new rig!
- Yet another Newbie! Code 27 Help
- How far can the 3.0 go?
- '88 steering wheel horn buttons
- Very Loud Vibration/grinding Noise
- Are all 2nd gen 5spds a workout to shift?
- Lowered 94 4x4
- My Cruiser Coil/BJ Spacer Lift Thread.
- 3vze Auto Trans 22RE auto trans
- Lowering a 4WD!
- 1993 3.0 stumble issue
- Muffer
- gauge temperature stays on cold position.
- Newbie introduction
- Recaro seats installed on my 87 pickup
- 22re Oil pump shim/pressure improvement?
- 3VZE Camshaft Position
- digtal dash
- motor size question?
- What relays are these pls.
- Front Wheel cap?
- 1990 4runner starter problem
- Random overheating issue...Please help my buddy!
- 22re - 3vz engine swap
- GEAR QUESTION, I don't no what I have!!
- Hood Scoop ?
- Twin turbo 3vze idea.....
- newbie picked up new ride
- gear/clutch damage caused by clutch start?
- oil or lube new timing chain?
- High idle question...
- 3VZ-E Oil dipstick installation
- Vacuum pressure test
- rear brakes stuck..
- 89 Pickup Engine Problems
- fuel injector fix gone wrong.(come on guys one of you has my answer)
- Help with AC
- Do I need tranny ...
- A340h Ect Help
- Throttle Position Sensor Reminder
- ARB Problem
- Tranny heat?
- 5.0 swap questions
- 22re 3vze radiator difference?
- 22RE blown head gasket cure?
- Inexpensive Upgrades
- round muffler or oval - whats the diff?
- Need help making buying decision
- Recently rolled 4-runner now it wont start, why wont it ??
- timing chain cover and oil pan-need some help
- Katie's 3VZE head gasket job!
- truck running funny lately...just a question
- balljoint spacers and shocks
- 2nd-gen harmonic balancer tools
- new wheels and tires, lift or not?
- Weekend of updates -Ford filter installed
- Need advice/opinion's on my suspension, tires, everything
- Fix gone wrong
- Lift Kit?
- '88 pickup sway bars
- Where to get a bedside?
- What should I expect to pay for the machine shop to do my bottom end?
- Automatic Transmission noise
- 88 4runner Transmission Issues
- Second gear doesn't work...
- removing 3" body lift blocks
- Spark Plug wires
- Knock sensor?
- 5.29's w/ 34's
- gas tank ?
- Vaccuum leak at exhaust manifold
- Locker for 95?
- body lift kit
- The Warn bumper *PICS*
- Fuel injector boss on lower intake manifold
- 95 Runner Rear Window Wiring
- v6 oil leak needs some advice
- V-6 Identification
- o2 senser
- 22re 4WD question?
- '98 4runner w/supercharger hesitation
- 86 22r running rough
- is it normal???
- Dash swap for 1988 pickup
- headlight electrical issue
- 3vze water outlet question
- Timing chain trick?
- 3VZE Creeping Timing (belt) marks ??
- Getting ready to pull the block out! Pic!
- Axle problems?
- noise from front end in 4wd
- 5mge question- Oilpan
- Burned valve diagnosis
- aaargh! stupid tensioner
- cooling system stop leak that WON'T plug your radiator
- Are the cam's different
- Weasy's Cams for 3vze.
- 22re rattling noise when under load
- Engine Block Heater
- Aisin Hubs
- REVIEW: Warn bumper for gen2/ 86-95 pickup
- Rear Coils
- Check engine light
- first time run after a rebuild and break in
- should I or shouldnt I, synthetic
- need some mirror help...
- POWERLESS when cold
- Rear main seal question
- Short & Long block recommendations
- 22RE timing and idle issue
- ISR mod question
- Starting problem
- used EGR valve?
- Overheating When COLD!
- help me PLEASE?
- 3.4 air filter
- starter or something else?
- 88 pickup swap
- a.d.d. to aisin hubs
- 3vze Fuel Injector Spacer broken
- Do ALL 2nd gen 4Runners sag in the rear?
- 3VZ-E shuts of instantly.
- Rear Bilstein Install Question
- 22RE series - anyone running an aftermarket coil
- Which Diff Gears to use
- timing belt change, now no start
- Uh Oh...CEL Attack!
- Engine Swap- 3.0 L V6
- Front Diff writeups?
- criuse control issue
- 3.4 swap motor mounts in an 87, what to use?
- My O/D light won't fash a code?
- Heater control cable binding
- Head Job #2
- Cruise Control for 3.4 Conversion
- 95 4runner update time to throw in the towel?
- 22R = 22RE Head studs?
- anyone had a V6 act like this?
- Anyone heard of this engine company ?
- 3vze radiator in my 22re, no fan?
- FROR bumper?
- Main oil seal
- Engine misses...
- How to remove sticky stuff from guage cluster
- Locking Up The Front. Locker-Less
- Front pump seal replacement help
- Clutch Slave cylinder
- What is this sensor (pics)
- I need heat!
- timing chain tensioner?
- Tach question
- Walbro pump for 94 pickup?
- '93 4runner rear window/wiper relay.
- will '99 arb fit
- How to bump idle speed on '94 3vze?
- Rear bumper bracket for a 3 in BL
- HG installation pictures
- Paint Question?
- fuel pump replacement questions
- remote start without clutch switch bi-pass!
- Replacing Front Diff in '90 4Runner
- Fuel Pump prices...
- Need a motor and need some opinions.
- 2 door 4 Runner parts compatability?
- tach wire?
- Marlin Rear Bumper for 4Runner
- Will 3VZ-E from from auto mate to a 5-speed?
- How hard is it to change from efi to carb setup?
- Valve Lash Adjusters
- New oil seal grease + packing
- Code 25- Please help diagnose
