body lift kit
Old Jan 21, 2007 | 01:26 PM
olharleyman's Avatar
body lift kit
Anyone with any kind of experence with a 2" body for a 1990 4 runner please help. Looking for a nice body lift kit to give that little extra cushion for the 35s I am putting on my runner. I know that i dont want one of them cheap ebay jobs so please any good kit numbers and manufacturer would be very helpful pros and cons of kit even better. Aready have a pro comp stage 2 suspension lift on truck.
Old Jan 21, 2007 | 01:28 PM
rocket's Avatar
www.4crawler.com
Old Jan 21, 2007 | 01:40 PM
Kyle95sr5's Avatar
Originally Posted by rocket
x2. Is yours an auto?
Old Jan 21, 2007 | 02:44 PM
5 speed
Old Jan 21, 2007 | 02:58 PM
mt_goat's Avatar
X3, Roger is the man.
Old Jan 21, 2007 | 03:01 PM
Kyle95sr5's Avatar
Do you "need" a 2 inch body lift or will a 1 inch work. You want to lift as little as possible and that holds especially true to a body lift. You already gonna be really tippy with your susp. lift and 35s, might not want to go that extra inch if you don't need to. Another plus if you keep it to one inch, you wont need to mess with the radiator or shifter, and you can drill new holes in front bumper brackets to work. If your only gonna go 1 inch, you might also want to check out http://wabfab.org/products/bodylifts/bodylifts.htm. Same product and same great customer serivce just for a little cheaper.
Old Jan 21, 2007 | 03:04 PM
rocket's Avatar
Originally Posted by olharleyman
5 speed
You should consider a 1" BL then. A 2" BL with a 5spd is a bit too much...makes for a lot of extra work/parts. Besides, with a 1" BL and that suspension lift you already have, 35's will fit easy.
Is your truck for show or trail use?
Old Jan 21, 2007 | 04:56 PM
mt_goat's Avatar
Yeah a little goes a long way with a BL. Roger will also do fractional sizes so you could do a 1.25" or 1.5" too, if you really want more than an inch.
Old Jan 21, 2007 | 05:36 PM
Its a dd and weekend warrior guess 1 inch will work dont really want that but need to make sure 35s will be fine with just suspension lift.was told my someone it wont work without body lift but if i need one guess ill go to wabfab or 4crawler for a fractional but have had very good luck with all i have got from wabfab.
Old Jan 21, 2007 | 07:10 PM
CLEANSR5's Avatar
Roger Brown=Body Lift Master
Old Jan 21, 2007 | 08:28 PM
Numbchux's Avatar
roger @ 4crawler also makes shifter extensions....
BUT, I'd go with a 2" Body lift, and a 2" drivetrain lift. it simplifies alot of things, AND gives you tons more clearance. roger makes engine mount blocks, and www.budbuilt.com makes preformed, bolt-on tcase crossmembers preformed to accomodate drivetrain lifts....
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Backcountry411
Jul 24, 2015 08:06 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
