A340h Ect Help
Old Jan 22, 2007 | 10:49 PM
THRASHER's Avatar
A340h Ect Help
My 86 4runner Is Starting Out In 3rd Sometimes 4th Gear ,i Manually Shift My Auto And I Have Tested A Lot Of The Electrcal All Exept The Trans/transfer Thermo Switch Sensor... Could That Thing Cause The Solenoids To Not Lock Up??? I Know It Wont Upshift 3rd To O.d... Without Warming Up The Tranny Oil To A Certain Temp.the Reason Im Asking This Is The Damn Thing Works Fine Once In A While. But Not Until The Tranny Heats Up Ive Pulled Codes 61,62 But I Dont Think Its The Solenoids Can They Be Intermiden??? I Have Not Checked The Speed Sensors Yet.can Anyone Help Me???. I Could Sure Use It Im No Mechanic. Thanks...
Old Jan 23, 2007 | 08:12 PM
meswoleshane's Avatar
Just get new solenoids. I replaced mine in my backyard in about an hour. Works great now.
Old Jan 23, 2007 | 08:14 PM
From what I've seen the ecu will throw codes because its not shifting right. After replacing mine all the other codes stoped going off.
Old Jan 24, 2007 | 09:14 AM
DH6twinotter's Avatar
Meswoleshane--did you use OEM or aftermarket solenoids? My 4Runner looses 1st and sometimes 2nd when it's warmed up. Pretty sure it's my #1 shift solenoid.
Daniel
Old Jan 24, 2007 | 08:25 PM
I used the solenoids out of a jeep. they have the same "read VERY similar" auto tranny. I got them from a u-pull-it junk yard for $6, $2 each. bolt right in and the connections are the same. Their overall size is a little bigger though. They work great, and its awsome not to haft to shift manually and start out in 2nd or 3rd.
Old Jan 24, 2007 | 08:28 PM
BTW some of the part #'s cross from the toyota a340 and the jeep aw4. The solenoids are also the same solenoids used in alot of vehicles as well.
Old Jan 24, 2007 | 08:46 PM
steelydan's Avatar
THRASHER:
The ECU uses the coolant temp to determine upshift to OD and torque convertor lock-up. Verify that your Coolant temp sensor wires are not corroded.
Shift solenoids can be NO (normally open) or NC (normally closed) be careful when purchasing from a recycler that you get the right ones that you need. FWIW I had shift problems with mine code 61 I think. I removed the shift solenoid and re-soldered connections, tested on the battery and it worked. Re-installed and it has been good ever since.
Old Feb 11, 2007 | 04:53 AM
THRASHER's Avatar
Thanks, all u guys for the helpful advice.- UPDATE- I actually made that call to the damn stealership yesterday.there going to charge me 196.00 for 1 solenoid good thing its not the lock-up!!!
Longbed 90
Mar 11, 2019 12:38 PM
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
Longbed 90
Oct 19, 2015 11:05 AM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 20, 2015 06:15 PM
