'98 4runner w/supercharger hesitation
Old Jan 21, 2007 | 06:15 AM
Choopster's Avatar
I have just purchased a 98 4runner with 113,00 miles. It has the TRD supercharger and a K&N cold air induction system. It is a manual transmission truck. When I pursue a WOT it coughs and jumps along. If I pursue a throttle slowly it seems to do OK. Also on the highway in cruise mode it will begin to jump at times under a load going up a hill and clear up when the extra load is removed. I have not changed the plugs and the wires are date coded with 1997. I have pulled off the induction tube and throughly cleaned the throttle body. I would appreciate any help. Thanks...
Old Jan 21, 2007 | 06:17 AM
chimmike's Avatar
sounds like an ignition thing...I would change all the plugs and wires, and the cap/rotor.
Old Jan 21, 2007 | 08:08 AM
mt_goat's Avatar
You may want to repost this in the correct forum folder, or maybe the mods will move it for you. You'll get much more help in this folder: https://www.yotatech.com/forums/foru....php?forumid=2
Old Jan 21, 2007 | 08:13 AM
TRDatVT's Avatar
no cap and rotor, but if the truck isnt tuned correctly (bringing up another point, what fuel mods do you have) plugs can be fouled very quickly! Do not use platinum plugs either, its not worth it... just gap down a set of NGK v-power copper plugs... cheaper and you should change them every 2 oil changes!
Old Jan 21, 2007 | 08:20 AM
mt_goat's Avatar
Exactly, and a supercharger without fuel mods will run dangeriously lean at WOT. You can ruin the motor that way.
Here's some reading for you:
http://www.gadgetonline.com/Super.ht...%20its%20self:
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
colinmil
Jul 6, 2015 04:03 PM
