3VZ-E shuts of instantly.
Old Jan 19, 2007 | 09:35 AM
CEbeling's Avatar
3.0 3VZ-E 90' 4Runner.
Cliff notes: Blew up engine. Put remanufactured engine in. Working out bugs.
So I got my Engine Coolant Temperature Sensor in. The truck runs allot smoother, but when you fire it up it dies almost instantly. The gauge cluster turns off and restarts. The exhaust smells like a lawn mower.. Its seems to running rich. I really need some suggestions guys. Please help I really want my yota healthy again....
I pulled
code 22
--WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
--WATER TEMPERATURE SENSOR CIRCUIT
--ECU
code 24
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
code31
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
Old Jan 19, 2007 | 10:26 AM
CEbeling's Avatar
Three sensors on this same sensor block are throwing codes. They all lead back to the ecu.....ill try checking the connections to the ecu.
Old Jan 19, 2007 | 01:20 PM
thook's Avatar
Do you have a good volt/ohm meter?
Old Jan 20, 2007 | 09:12 AM
JLSpeed's Avatar
I do! I figured it out man.... loose connections.
Old Jan 25, 2007 | 10:23 AM
thook's Avatar
Well, great! I'm just confused...am I talking to a split personality here? Two user names? Two different people?
splangeland
Apr 6, 2024 08:14 PM
Corvoid
Dec 11, 2015 11:21 AM
voiddweller
Sep 28, 2015 11:21 PM
runnermedic
13
Sep 21, 2015 05:20 PM
SCZIG
Sep 20, 2015 09:00 AM
