1993 3.0 stumble issue
Old Jan 23, 2007 | 06:46 PM
hillbllydelux's Avatar
93 4runner with 230,00 miles runs good except for a stumble at slow idle under a load, so i searched forums and tried disconecting the egr vaccum...solved problem plugged off vaccum port...so today when i accelerate theres no power then at like 3 grand it hits like a cannon. this isnt the usual high rpm pickup that usually happens. sometimes i have no power whatsoever and it idles fine....any ideas similar problems?
Old Jan 24, 2007 | 06:26 AM
WillRadford's Avatar
Ya, my 3.0 with 175k miles will run great until it is fully warmed up and then the performance drops off. It'll kind of stumble when I accelerate until the rpms are above 3000 or so. But if I shut the car off and then start it again it'll run good again for about 5 minutes then it comes back. I had a code 71 come up so I think I just need to clean out or replace the EGR valve and piping. Its just such a pain to get that thing off the exhaust manifold without taking the whole top of the engine off. Has your check engine light come on?
Old Jan 24, 2007 | 06:56 AM
CEbeling's Avatar
I am having the same problem in my truck. Just finnished up an engine swap and its the last problem along with a high idle.
subscribed..
Old Jan 24, 2007 | 10:10 AM
also it shows no codes now that the egr is unplugged ive driven it plenty of time and still hasnt thrown a code....what would this indicate electrical issue
Old Jan 24, 2007 | 05:11 PM
BC Rider's Avatar
I had a "hit" like you describe at one time. It felt like a 2stroke motocrosser.
I changed out the spark plug wires and it was all fine after that. Used oem parts.
Not sure how old yours are, but the two-stroke hit could easily be related to poor spark at low rpm.
Old Jan 30, 2007 | 05:53 PM
ok egr still un plugged took throttle body off checked tps and its fine maybe not perfect adjustment but thats not the culprit. no power at all but if i let off the gas and get back into it its fine so this weekend
fuel filter
wires
plugs a month ago but will check
check maf sensor
any other ideas its getting progressively worse....fuel pump going?\
thanks in advance
Old Jan 30, 2007 | 06:02 PM
MudHippy's Avatar
I've got my EGR by-passed (cork in the plenum hole,at connect point), did it for a slight hp gain at higher rpm, plus I'm legal doin' it where I live. No code on ECU here with it done like that. If you don't know how old that fuel filter is I bet that's it. Mine was full of $#@! when I changed it a week ago, don't know how long on that one, HUGE DIFFERENCE afterward.
Old Jan 31, 2007 | 07:31 PM
plugged egr back in unplugged tps and the truck runs amazing so gonna go ahead and get the tps
Old Feb 1, 2007 | 09:00 AM
LS1Steve's Avatar
mine was acting similarly (same mileage on my truck) and was recently tuned up. I had never changed the o2 sensor though, ever. I recently did....its a whole different truck!
Charecter1
Nov 6, 2023 10:08 AM
XtraCab
Apr 12, 2020 05:25 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
