What is this sensor (pics)
Old Jan 18, 2007 | 12:12 PM
CEbeling's Avatar
What the heck is this sensor on the 3vze 90' 4Runner. It broke off and it needs to be replaced... maybe..
help please!!
Old Jan 18, 2007 | 12:15 PM
the_4runnin'_beast's Avatar
What part is that?
Old Jan 18, 2007 | 12:16 PM
da_bigg_wigg's Avatar
Yeah, I'm just trying to figure out what you're holding there...
Old Jan 18, 2007 | 12:20 PM
19RUNNER86's Avatar
year make model?
19RUNNER86's Avatar
also where is this located on your truck?
Old Jan 18, 2007 | 12:40 PM
callmej75's Avatar
Cold start injector time switch? This is off the 3.0...
Old Jan 18, 2007 | 12:42 PM
Ahh. Then, yes. You need a new sensor. Its name?... Hell I don't know.
Old Jan 18, 2007 | 12:48 PM
95SlowRunner's Avatar
Broke the same piece on mine don't remember what it was but does have two vacum lines attached. I would replace it.
Located on the back of the lower intake manifold.
Old Jan 18, 2007 | 12:51 PM
Bassinfool's Avatar
Broke mine, too. It sits behind the intake plenum attached to the top of the block IIRC. I think it was still like $75 from the wrecker. Amazing!
Edit: '92 3VZ, by the way.
callmej75's Avatar
The sensor with the 2 vacuum lines is far right in the pic...or I'm just getting old and can't see that well!
Old Jan 18, 2007 | 12:53 PM
Bassinfool's Avatar
I don't think so. The far right has a coolant hose attached to it. I think that's the two-vaccuum line sensor.
Old Jan 18, 2007 | 01:03 PM
callmej75's Avatar
You would be correct...my mistake! Its the one with the 2 vacuum lines.
Old Jan 18, 2007 | 01:05 PM
callmej75's Avatar
Its the TVV for the EVAP system
Old Jan 18, 2007 | 01:39 PM
CEbeling's Avatar
Yes sorry 90' Toyota 4runner 3vze. Sits right behind the intake manifold. Its a whole bunch of sensor.
Old Jan 18, 2007 | 01:58 PM
thook's Avatar
Sure that's not the ECT sensor? Uh..nevermind, that's on a ''92. Nevermind me...proceed.
Old Jan 18, 2007 | 02:03 PM
CEbeling's Avatar
Its NOT the TVV sensor. I just checked the truck and its all connected and working properly. its directly behind the TVV sensor. Its circled in the top picture... Please yotatech help me find out what this sensor is!!!
Old Jan 18, 2007 | 02:13 PM
thook's Avatar
I say ECT. Engine coolant temp. Flashing any codes?
EDIT: WERE you flashing any codes?
Old Jan 18, 2007 | 02:16 PM
CEbeling's Avatar
ooo I dont know how to make it flash codes, but i know how to swap the engine ... this is my first toyota... whats the procedure
Old Jan 18, 2007 | 02:18 PM
CEbeling's Avatar
When we fired it up and let it ran the idle bounced around... but the temp guage on the cluster began to rise....
Old Jan 18, 2007 | 02:30 PM
thook's Avatar
Hmmm.....sounds like what mine did before I replaced the ECT...the idle bouncing that is. The temp gauge is probably your thermostat. Pull the broken sensor out and see if it's kinda greenish and rusty.
Oh! And to pull the codes, there's two terminals on the diagnostic thingy at the passenger side wheel well. It's a little grey box with a flip up lid. I think the terminals are TE1 and E1, but that's probably wrong. There's threads on pulling the codes, anway. You just have to jumper the two correct terminals with a wire or paper clip, turn the key on to ignition, and the check engine light will flash a certain number of times.
Better yet, here's the link..
http://www.off-road.com/toyota/tech/codes/index.html
